02-25-2013, 07:08 PM
#21
Oswego
Originally Posted by Alumaholic
Husky is good.
I find "Click" type is easier to use than "beam" type (I have both in 3/8 and 1/2)
Always "unload" your torque wrench when you aren't using it. (Adjust it back to zero)
Never use your torque wrench for a breaker bar.
Breaker bar - Wikipedia, the free encyclopedia
That's exactly why I think a torque stick in the AS would be good:
1 breaker bar and one torque stick and one socket
verses:
1 breaker bar, one torque wrench, one socket and 1 extension. Might save a couple pounds with the torque stick combo.
-Rich-
02-25-2013, 07:13 PM
#22
2019 27' Flying Cloud
Albuquerque
, New Mexico
Hmmm. Less is more. Can I purchase a 100# torque stick, or must I purchase a set?
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
02-25-2013, 07:16 PM
#23
Oswego
-Rich-
02-25-2013, 10:54 PM
#24
Salem
, Oregon
Hi, OK, don't get confused; Torque sticks only work with pneumatic impact wrenches/guns.
Note: Robert Cross used a slang term "Wind Wrench".
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-26-2013, 05:58 AM
#25
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
verses:
POI.... you need a wind wench to use a stick.
02-26-2013, 06:41 AM
#26
Oswego
Bob, not sure what you are saying (or the link), but it would be "easier" with a ratchet, but works equally well with any torqueing device (ratchet, impact, or breaker). With a breaker, you'd just have to remove the socket and start your "swing" over and over. I also disagree with the link poster's opinion of inaccuracy, per GM training and bulletins back in the mid 80s when they were REQUIRED for torqueing lug nuts on, over a torque wrench, due to potential stress warping brake rotors. There was a HUGE push for reduction of rotating and unsprung mass back then and the rotors/hubs were THIN! Torque sticks are generally considered more consistent than the operator of a torque wrench.
-Rich-
02-26-2013, 07:21 AM
#27
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Rich,
I agree they are much more consistent.
But was always instructed that it is the flex action of the stick that caused the impact wrench to ratchet.
Seems to me it would be very difficult to note that flex visually.
I will admit though I have never tried using one without the wind wench.
Quotes from my tool archive...
"Torque sticks are used with an impact wrench and are flexible. This limits the amount of torque that can be applied and prevents overtightening because they will bend once a certain torque has been reached. Their appeal lies in the fact that they are much faster than other means of applying and measuring torque, and they are also easy to use.
Accuracy,
Torque sticks are accurate. A study by General Motors found that torque sticks from one manufacturer were precise within two percent of a specified value, which is more precise than their advertised five percent. This may vary by manufacturer.
Will have to give it a try.
02-26-2013, 07:27 AM
#28
Oswego
Give it a try and let us know. I know they always talk about them with impacts....but that was the reason they were invented....for speed and stall efficiency where time is money. I know you know what I am talking about! If you use them in a shop with a hand ratchet or breaker, you might as well get out the torque wrench....no faster.
If I understand the internals (there's a couple of different designs) they work just like the twist dial torque wrenches....you'll feel a "slip/knock" when you're there. HOWEVER, I THINK that if you ignore the slip/knock you can keep torqueing up the lug nut, just like a torque wrench. An impact can't do that, by it's design.
-Rich-
02-26-2013, 07:47 AM
#29
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"I know you know what I am talking about!"
Ahh yes, the old "flat rate" conundrum.
Tech...
"What!!! only .2hr to change the tire."
Service adviser...
"How would you feel paying the 20bucks?"
Only good answer, menu pricing...been on both sides.
POI...
When I first started we got a straight % of customer and warranty labor rate. (book time)
I always felt it was a pretty fair, rate goes up, we got a raise.
Any GM stores still using that flat rate method?
02-26-2013, 08:03 AM
#30
Oswego
Yeah, (I'm not too close to the franchised shops anymore. I hang out in fleet customer shops a lot more than dealers in the last 20 years.) I think some the union shops will use the formula method. I think it depends on the local area and which method works better financially. But, union agreements can affect that as well.
-Rich-
03-17-2013, 08:47 PM
#31
1988 32' Excella
Robbinsville
, New Jersey
verses:
You could use a torque adapter instead of a torque stick.
Alltrade 940759 Powerbuilt Digital Torque Adaptor for 1/2-Inch Driver - Amazon.com
03-18-2013, 10:51 AM
#32
1981 31' Excella II
New Market
, Alabama
I like the torque adapter device.
Perry
03-18-2013, 04:47 PM
#33
Albuquerque
, New Mexico
Way to Go, Perry
Now I have to buy one (SIGH).
03-18-2013, 06:21 PM
#34
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
03-18-2013, 09:33 PM
#35
Salem
, Oregon
Originally Posted by ROBERT CROSS
Hi, in the good ole days it was just done by feel. "Feels tight enough for me." Never had a problem.
03-19-2013, 04:20 AM
#36
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Plus.....I always knew that if I had the strength to twist 'em tight, I could most likely twist 'em loose.
03-19-2013, 06:05 AM
#37
2005 30' Classic
Burlington
, Ontario
Ah yes, "Professor Gudentite's principle!"
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
03-19-2013, 06:08 AM
#38
1981 31' Excella II
New Market
, Alabama
I am an engineer and I use the Robert Cross's Cross Method and it has never failed me. About the only thing I use a torque wrench on is on something like a head gasket. I also use one for the spark plugs on my Excursion since Ford decided to put 4 threads on the spark plugs. By the way, 15 ft-lbs on a spark plug is not enough to keep it from coming out. 20 ft-lb plus is more like it. Even with 4 threads the plug will break before the threads strip. In fact the plug will fail at about 100 ft-lbs. The problem is that they get loose then let go.
Perry
03-19-2013, 06:49 AM
#39
1999 34' Excella
Hillsboro
Go to NASA.gov.
Search "thread torque ".
Have fun!
Peace and Blessings..
Channing
WBCCI# 30676
