Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-03-2009, 05:34 PM   #1
1970 27' Overlander
Ketchum Idaho , Idaho
Heater turning to cold air in middle of night
our 70' Overlander orig heater works great except that sometime in the middle of the night it turns to cold air....
its going to get to freezing tonight...
we need some help figuring this one out
Thanks!
zenarmy is offline   Reply With Quote
Old 12-03-2009, 06:18 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
All heaters will blow cold air at the end of a cycle. This is to cool the heat exchanger before the fan goes off. That should last about 1 min.
If your heater is blowing cold air for a longer period it may be an over heat switch opening. If that is the case it is time to have someone look at the heater as the over heat switch is a safety and realy should not have to come on unless something is wrong.
2004 Excursion 4x4
Old 12-03-2009, 06:22 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Copper plumbing is more susceptible to frost damage.
weather.com says Carson City is headed to 22 degrees tomorrow (probably pre-dawn), 16 degrees on Saturday and 21 degrees on Sunday.
Your furnace has ducts that go down to the tanks - coverage may miss some spots if you are really borderline -- I qualify that as temps in the teens or below.
A furnace that is not working? Member Leipper (Reno?) measured temps in his Airstream after temps around 20 degrees overnight. His experience - without wind outside, you may not see temps inside go below freezing. But always judge that down at floor level. You actually are going lower by Saturday.
What I would do? Buy some RV antifreeze and fill your traps -- especially those at the floor; eg shower. Drain your fresh water tank -- add back a couple gallons of water and $20-30 of the cheapest vodka you can find. Run the pump, emphasizing the outside lines most. For instance, shower mixer valves in outside walls are more susceptible to freeze damage -- and extraordinarily hard to access once ruined. Unreliable furnace? Get an inexpensive space heater, plug in to 120 volts, and run the space heater with lower cabinet doors near plumbing opened.
Put a thermometer at floor level near your plumbing. Monitor it in the mornings to see what effect you are having. Vodka in the fresh water tank is easier to purge than RV antifreeze -- and potentially more interesting for the goldfish...
5 meter Langford Nahanni
Old 12-04-2009, 06:13 AM   #4
1977 Argosy 24
Milltown , Wisconsin
A space heater with the AS furnace fan running will distribute the heat through out the trailer via the duct work.
ventport is offline   Reply With Quote
Old 05-04-2012, 09:48 PM   #5
Full Timers
1975 31' Excella 500
Boise , Idaho
I have a problem with my furnace. When it is running it will blow somewhat cold air out of the inside vents and the exhaust outside is somewhat hot. Does anyone know what the problem might be? There is a flame but it looks like it may need to be adjusted because it is partially yellow.
PotatoPeach is offline   Reply With Quote
Old 05-04-2012, 10:20 PM   #6
1974 Argosy 20
Kooskia , Idaho
Thanks!
Pretty common problem on the older furnaces. Two or three things may be causing it.
1: low voltage. When the battery gets down, the voltage drops below the necessary range to keep the gas valve open. That is generally 10.5 volts. Cause is a low battery, poor connections, poor grounds etc. You will need as high a voltage AT THE FURNACE as possible. Voltage drop through the wiring makes it important to measure it at the furnace.
2: Slow blower speed due to low voltage (see above) which causes the sail switch to drop out, shutting the power off to the gas valve. Also, the blower speed might be slow, just due to old age.
3: This is the hardest one to find, and is generally solved by replacement rather than testing.... the high limit over temp klickson switch has become interminent. On your original no circuit board furnace, if the temp of the interior of the furnace goes too high (and this is common, due to small ducts and low blower speeds) there is a little switch called a Klickson (brand name) which will shut the gas valve off until the heat is dissipated by the blower. The real name is the "high temperature limit switch" These switches get old and tired and when they open, they shut the gas off, but when they close, the contact does not make good and the gas valve will not come back on. Often, when completely cool, and run through another cycle from scratch, they will start to work again, but then fail again. In other words they become intermintent, which can drive you crazy finding the problem.
So, on your old pilot light furnace, I am pretty sure one of those three things is causing your problem. There is a slight possibility that the gas valve itself is defective and is temp sensitive, but that is not too common.
Have fun!
Old 05-04-2012, 10:49 PM   #7
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Get an air compressor or a clean out brush and make sure you haven't got a little spider-nest or something blocking the burner. After periods of non-use you can get things like that happening. Yellow flame means not enough air...
Friday is offline   Reply With Quote
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-26-2013 11:14 PM
drafts..cold air katsix Member Introductions 13 12-14-2007 10:56 AM
Furnace blows cold air guy99 Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-06-2007 10:26 PM
Middle Twins to Middle or Rear Queen? fastrob General Interior Topics 12 02-27-2006 02:12 PM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
