11-17-2009, 07:21 AM
Tucson
, AZ
Fire extinguisher - Where & How Many
Soooooo, where do you keep your fire extinguisher? I have only one and keep it in my kitchen pantry. On second (or third) thought, I don't think this is an appropriate place. I dislike the look of it hanging on a wall, but.... I even wonder if I should have a couple and place them in differing areas.
Oh, and what type do you carry. I found one RV website that says it should be BC rated. But, in the same article, it mentions that many RV fires are of A type. ???
Thanks for your thoughts,
Laura
11-17-2009, 07:31 AM
Greeeneville
, Tennessee
I keep one in the area where I sleep. I also have one in the kitchen in case of a fire in that area.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
11-17-2009, 07:38 AM
2008 22' Safari
Oracle
One just inside the doorway and onother in the TV.
11-17-2009, 07:41 AM
2019 28' International
Leonardtown
, Maryland
One in bed room near door and one in kitchen area next to exterior door and both in full view and easy access.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
11-17-2009, 07:54 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
One is mounted on the wall near the floor by the main entry door and the other is in the bedroom on the wall near the floor. I got 2.5# ABC's for mine. Had to go to a regular fire extinguisher service shop for that type. This way I am cover for all types of fires even outside the coach. In addition, the TV also has 10# ABC.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
11-17-2009, 08:13 AM
2007 25' Safari FB SE
North/East
, New Jersey
We have the standard one by the entrence door, a second one in the closet next to the bed. I also installed a Fireboy automatic (FE241 chemical) fire extingusher in my refrigerator compartment after having the Dometic recall work done.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
11-17-2009, 08:16 AM
One in the kitchen area by the entrance door.
One by the bed (Center bath model).
One in the TV cab.
Kevin
William C. Swinney
1977 27' Overlander
Trotwood
, Ohio
We carry two . 1 1lb thats just inside the door on a bracket and 1/ 5 lbs both are ABC.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
11-17-2009, 08:18 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Ours came with one mounted near the door and another mounted on the wall in the bedroom. As I feel kind of good about that, it occurs to me that I should find it ironic that I don't know where the one in my house is.
I knew there was something else I needed from Home Depot today.
Pat
11-17-2009, 08:34 AM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
We have the one by the door near the kitchen but it never occurred to me to have one in the rear bedroom area. At first blush, it seems overkill to have two extinguishers to cover a 250 square foot space but maybe two is the right way to go. Thanks for the heads up.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
11-17-2009, 08:50 AM
1972 31' Sovereign
Lexington
Just a thought - if you're in the back of the trailer, and the stove/oven is the source of a fire, you really do not want to try and get past the burning stove to get to the fire extinguisher. Having a second one in the bedroom area is really cheap peace of mind insurance. One by the door is pretty standard, because you can reach it easily from both inside and outside. My 2 cents.
Chris
11-17-2009, 09:51 AM
2019 27' Tommy Bahama
Roseville
We have 3....a large one kept in the closet, a small one in the bedroom, and a small one by the door, reachable from outside. All of ours are ABC (dry chemical)....however, a member of the AirForums, who is also a fireman, told us at a rally that we should have carbon dioxide extinguishers.
2019 27' Airstream Tommy Bahama
2011 GMC 3500HD Duramax
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
11-17-2009, 10:22 AM
Tucson
, AZ
I had to look that one up. Looks like the CO2 extinguishers are for Class B & C also.
So, this leads me to another question. Seems most recommend the BC extinguishers. These fight the flammable liquid & electrical fires. Whereas the Class A is for ordinary combustibles (wood, paper, cloth). If you're fighting a fire caused by electrical - Class C, wouldn't you also need to extinguish the other parts on fire -Class A?
Thanks for all the ideas. I'm going shopping.
Laura
11-17-2009, 11:29 AM
Tucson
, AZ
Originally Posted by 2airishuman
lots of threads on this,
here is 1 with much good info.
cheers
2air'
Man, I google searched under "fire extinguisher" and looked through the first page of hits with nuthin' really relevant. Figures. Thanks 2air!
11-17-2009, 02:17 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
.....and don't forget to maintain your extinguisher(s) too.
Care and Maintenance of your Fire Extinguisher
Ricky
11-17-2009, 02:32 PM
Halimer
2006 25' Classic
New Hyde Park
, New York
I have the factory supplied one by the door, one in the bedroom, one in the lower street side compartment, one in the TV. Received my advice/info from a local fire marshall/RVer. Better safe and sorry.
11-17-2009, 03:18 PM
1978 Argosy Minuet 7.3 Metre
Dayton
I have one by the door and the second in the rear in the bath closet
Al
11-17-2009, 04:57 PM
Halimer
2006 25' Classic
New Hyde Park
, New York
I meant 'better safe than sorry". Brain fart.
11-17-2009, 05:39 PM
1968 17' Caravel
Battle Ground
Since it's a Caravel, we like to say that by the time you notice, you're probably already on fire! Not a lot of room in there But we do have an ABC by the door. Unless the kitchen area burst into flames while you were in the toidy, you're probably already as close to the door as you're going to get. In an emergency we could head out the back window.
As for the TV, it's one of those highly flammable Fords, so maybe I should look into an onboard fire suppression system - but barring that, a fire extinguisher would probably be a really good idea.
Have there ever been studies about the most likely causes of RV fires?
Stephanie
