08-31-2015, 07:29 PM
2015 28' Flying Cloud
2018 33' Classic
Cumming
, Georgia
Cheap plastic door latches
2015 FC 28. What's up with these cheap latches. Screws keep falling out. Have tried putting kitchen match pieces and rescrewing; no good. Better ideas??? Please
08-31-2015, 07:33 PM
Biloxi
, Mississippi
Contractor grade. Cheapest they could find. Epoxy and oversized screws usually help.
MICHAEL
08-31-2015, 07:39 PM
Retired.
, At Large
If they're machine screws, try putting a drop of blue thread locker on the threads, and screwing them in.
08-31-2015, 07:42 PM
2015 25' FB International
my
, house
I've had a couple come out. Filled stripped hole with PC11 epoxy,available at most hardware or big box stores. Let cure 24hr minimum. Drill and reinstall screw. Will hold very well if not over torqued. Be careful not to drill too deep and going through door.
08-31-2015, 08:53 PM
2002 30' Classic S/O
Fleming Island
What bwpaint said. That's how I fixed one of mine. The PO had just put in a bigger screw. That was a fail. Epoxy holding well.
Al
09-01-2015, 11:48 AM
2016 25' Flying Cloud
Mine did the same on the closet door. I bought screws that were a bit longer. So far it's working. We have a 2016 25FB Flying Cloud.
09-01-2015, 12:27 PM
2014 30' Flying Cloud
Milton
, Ontario
Cheap latches
I have had the same problem on our 2014 FC 30. One latch has broken.
To your problem. Use 1/8" dowel wood with wood glue to plug the holes. Use a larger screw diameter . I can' t remember what size I used maybe a # 6 or 8. Measure the door thickness plus the latch flange then get the longest screw without it breaking through the door finish.
Norrie
09-01-2015, 01:00 PM
TinCan
2016 30' Classic
Apache Junction
All of the above. Toothpicks, glue then the screw. Usually works for me. Last time I tried a little wood filler along with glue and so far holding up.
TinCan
09-01-2015, 01:09 PM
1972 29' Ambassador
Boynton Beach
For an absolutely bullet-proof overkill fix, drill oversize holes (like 5/16"!) and fill them with thickened epoxy. I like micro-balloons or the sawdust from a belt-sander. When you drill the holes for the screws into that, it will hold for sure!
09-01-2015, 01:10 PM
2017 25' International
Carlsbad
Take a look here too
09-01-2015, 01:21 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
I use a mixture like Suzy said except that I put the screws back in right away - with oil on the threads. After the epoxy has set up, then I torque to proper holding level.
09-01-2015, 02:48 PM
2002 19' Bambi
Lafayette
Originally Posted by DoublTrouble
I have been curious about what latches are being discussed here, particularly since most posts revolve around loose screws which the latches themselves are not responsible for. So I was pleased to see the picture DoublTrouble refers to so I would know what latches are involved and if my trailer has them, too.
Our 2002 19' Bambi has them and they have caused no problems over the last 13 years, so maybe how the screws fasten into newer cabinets is the main difficulty.
Are the latches "Contractor grade. The cheapest they could find."? Well, the brand in our trailer is Southco and they are marine grade (i.e. boat), a quality not usually thought of as poor. A common retail price is about $15 per latch, not exactly cheap.
Tim
09-01-2015, 03:20 PM
2007 28' Classic
Ivanhoe
, Virginia
A small piece of plastic zip tie works very nicely.
09-01-2015, 03:33 PM
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
I wonder if when the latches are installed, I'm sure that the installer is using a drill to tighten and perhaps in an effort to hurry, he is tightening too much and compromising the supporting wood. The poor quality of the latch should have nothing to do with the fact that the screws come out. Oh... Don't ask me how I know about over tightening.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
09-01-2015, 03:56 PM
2016 27' Flying Cloud
Overland Park
, Kansas
Tim
Most of the latches on my 2014 FC look like this and are inexpensive at Camping World.
09-01-2015, 04:31 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
>>ron<<
Poor latch quality
Stripped wood screws.....
09-01-2015, 04:33 PM
Overland Park
, Kansas
Try post number 2978 (on page 213 of the full site version) too, Robert Cross posted great pictures, and a fix for the cheap latches.
09-01-2015, 06:12 PM
2016 23' Flying Cloud
leavenworth
mine did the same I put hard wood OAK in the holes and glue on the screw threads Gorilla
glue and screwed them back in.....there have been several things wrong and I believe Airstream has gone cheap (NON_UNION) plus inferior parts. FAN behind fridge,drain valve underneath by water tank just waiting for the next problem to arise.....no extended warranty too much money.
09-01-2015, 08:15 PM
leavenworth
use a hardwood (oak) to fill hole with glue then screw , readjust the latch so it's not too tight. Airstream is losing their Quality
09-01-2015, 08:29 PM
2012 25' Flying Cloud
Battle Lake
Just for the record our latches have never loosened, broken, or come unlatched when towing. We traveled extensively and lived in the Airstream over 24 months total.
There must be others with similar results. It may be someone(s) at the assembly line is over tightening the screws during assembly on some units.
Inland Andy has suggested this is a symptom of out-of-balanced running gear and/or too stiff a hitch connection.
Doug and Cheryl
