I would start by taking a voltage reading at the input of each magnet and both sides of the trailer plug and at the controller output. If it is the drivers side front wheel that is locking up it sounds like you have a voltage drop problem.
If you see a drop of more than 2 volts through the system I would start by upgrading the wiring where the drop is most noticeable.
Another point to test for a drop would be from the magnet output to battery ground with a piece of #12 or larger wire leading to the battery. Any voltage reading here is a problem in the ground path.
2004 Excursion 4x4
