Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 04-14-2003, 06:15 PM   #1
hhuber
hhuber's Avatar
Profile:
Images: 8
Unhappy New Tekonsha Prodigy.Old Trailer
I got my new Prodigy installed at the local RV place today.
It passed the simulator test and I was given a demonstration.
Got home and hooked up the trailer. The brake controller
does not pick up the brakes. The trailer brakes worked before.
Of course the RV guy said something is wrong with t he trailer.
Any suggestions? I fear we may never leave the backyard.
Heidi
hhuber is offline   Reply With Quote
Old 04-14-2003, 08:12 PM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Heidi!
If the trailer brakes worked before, and all that was done was to switch controllers in the tow vehicle then there is likely a corrossion problem in either the car or trailer end of the umbilical cord.
When I picked up my '64 Overlander at Ace Fogdall RV Saturday after its round of Winter Maintenance, all trailer features operated except the trailer brakes. As it turned out the terminal for the trailer brakes on the tow vehicle end of the umbilical cord arrangment had nearly disintegrated due to corrossion. A quick replacement with a new Pollack connector and the trailer was back on the road again. Had a similar problem with my '78 Argosy and its problem was with corrosion on the trailer end terminal - - it also required a new connector to get all functioning properly again.
All that is required to examine the terminals on your connectors is a fine "jewler's" style screw driver to remove the set screw - - depending upon how long it has been since it was last removed it might be a good idea to soak the set screw with penetrating oil. It would pay to be preapred with a new car and trailer end for your connectors so if a replacement is needed it can all be handled at once - - a wire cutting/stripping tool comes in handy for this process as well as a roll of heavy duty electrical tape to warp the connector before re-installation.
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 02:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 09:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 01:15 PM
