06-23-2009, 09:17 AM
1999 23' Safari
Austin
Brakes a DIY Project?
I have a 1999 23ft safari that has never had a brake job. I'm thinking about installing new backing plates on all four. Easy to do myself or should I pay a professional?
06-23-2009, 09:58 AM
Corona
Many owners change out the backing plates.
The only thing to pay attention to when mounting them is there are left and right hand backing plates.
The wiring is not polarized.
Of course, after they are mounted, you must adjust the brakes.
Depending on how many miles the trailer has on it, you might consider replacing the shocks, too.
Pack the bearings and replace the grease seals at the same time.
While your at it, install some Centramatic balancers, and take care of that problem as well.
06-23-2009, 10:15 AM
More than one rivet loose
Los Alamos
, New Mexico
How handy are you? Have you ever done drum brakes on a car? Are you changing the magnets? Do you have a friend that can help if needed?
If not get a professional.
Michelle TAC MT-0
Sarah, Snowball
06-23-2009, 10:50 AM
Master of Universe
2008 25' Safari FB SE
Grand Junction
Michelle is right. Do you figure out mechanical things easily, if you haven't done a brake job before?
Not sure why you need new backing plates unless you want self adjusting brakes, a technology only 40 or 50 years old that Airstream doesn't seem to have heard of. I have heard magnets only last 20,000 miles, so on 10-year-old trailer, surely you need them, shoes, springs.
When were the wheel bearings last repacked? There are plenty of threads on that.
Gene
06-23-2009, 10:58 AM
1979 23' Safari
1954 29' Liner
Orange
Gene
Gene,
It is cheaper to purchase fully loaded backing plates compared to the individual parts.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
06-23-2009, 01:20 PM
Master of Universe
Grand Junction
Bill, so they come with all the brake parts. Sounds like a good deal to me. I understand Dexter came out with a self adjusting option for the backer plate recently.
Gene
06-23-2009, 01:26 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
You need to see what you have first,pull drums,check them for groves & spider cracks.Check your shoes ,do they need to be replaced ? Don`t spend the money till you know what you need. Dave
06-23-2009, 02:01 PM
1979 23' Safari
1954 29' Liner
Orange
Gene
Gene,
Yep, cut the wires, unbolt the backing plates, rebolt the new plates and hook up the wires, and boom you are done. Self adjusting fully loaded backing plates are available also.
Bill
08-25-2009, 08:48 AM
1999 23' Safari
Austin
Well as many of you predicted the brake and bearing job was not that big a deal (except the temp here in Austin has been brutal). During the removal of the old backing plates I noticed that the electrical wires on one of the rear wheels had not connected? After a short trip of two miles I checked the temp on the hub and that wheel was warmer than the other three. Thinking I had done something wrong I tore it down and checked the bearings and readjusted the the brake. And it's still hotter than the other three. I've researched the threads on brakes and have not found any clues to my problem. Any suggestions??
08-25-2009, 08:59 AM
Master of Universe
Grand Junction
There is a variance on the heat of each wheel. How many degrees difference? Also, the sunny side will often be hotter than the other side.
I wonder what Andy meant by the wires are not polarized? Does it mean it doesn't make any difference which one is attached to the wires coming to the brakes?
Gene
08-25-2009, 09:08 AM
1999 23' Safari
Austin
I've purchased a digital infrared thermometer and will take a reading in the storage shed today and then when I've towed for a couple of miles and let you know the results. My understanding is the same as yours on the polarization issue, it does not make a difference which wire you connect to the backer plate.
08-25-2009, 09:25 AM
1967 22' Safari
1960 Caravel
Edmonds
Gene
Simply, It doesn't matter which way you hook up the wires.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
08-25-2009, 09:37 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
are the other 3 brakes working? you can try a very low speed quick stop to test and see if they all lock.
if they are they might be adjusted less tightly than the hot one and the hot one is activating first.
is the hot wheel spinning freely after it gets warm?
are the shoes seated correctly on the backing plate?
hare the hold down springs ok?
as an FYI, the brakes will drag slightly more after they get hot.
Ricky
09-16-2009, 05:12 AM
Ottawa
, ON
Originally Posted by wkerfoot
Gene,
Bill
What's a good place to buy those, please?
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
09-16-2009, 08:22 AM
1979 23' Safari
1954 29' Liner
Orange
There are several places on the internet, just google trailer parts.
Bill
09-16-2009, 08:31 AM
Master of Universe
Grand Junction
09-16-2009, 08:33 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
09-16-2009, 08:34 AM
1999 23' Safari
Austin
Finally took it to my local Airstream dealer and had them check out my brake job. The tech said the installation looked very good and he re adjusted all four to spec. He also confirmed the electrical flow to all four hubs. Hub still hot! Checked the bearings and all looked good. Still hot! Replaced the new backing plate on that wheel.....fixed the problem! My conclusion.. this is a DIY job that can save you lots of money if you have the right parts and those parts are not defective!
09-16-2009, 08:36 AM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
It's all DIY !!
everything on a airstream is easily done by the owner.
UNLESS you're the kind of person that could get both hands stuck in a vise !!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
