Old 09-28-2013, 09:26 AM   #21
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Dznf0g - I'm so tempted by centramatics or the ceramic beads (which according to TST won't be a problem with my internal sensors).
I had these installed together with the new Michelins and as a whole that's what got balanced.
Old 09-28-2013, 10:10 AM   #22
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
I have rubber stems and no TPMS yet. I purchased metal valve stem extenders for easier air checking/filling and found exactly the same thing - marks all over the wheels from the extenders swinging all over. I will be getting metal stems eventually.
Old 09-28-2013, 10:28 AM   #23
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I was reviewing the information I found for the TST tire system. I would like to know if these sensors need to be mounted internal to the tire or external on the valve stem. I think I saw both but am not sure.
I like the concept that they will monitor truck and trailer together and yet separately as needed. Some of us have trucks without their own sensing system.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-28-2013, 10:33 AM   #24
2005 19' Safari
GLENDALE , AZ
Any recommendations on metal tire valve stems? Sources?
Old 09-28-2013, 10:41 AM   #25
dznf0g's Avatar
Oswego , Illinois
I think these are the ones I got. After calling Tire Rack and Summit Racing, with no luck. The issue here is my Sendel wheels have a small diameter recess in the face of the stem hole, so I needed the ones with both lock nuts on the inside, rather than one outside and one inside. The .453 hole is the one I needed (I hope....some guessing here as I was measuring with current wheels assembled)
Flush Mount Metal Chrome Tire Valve Stems High Pressure Bolt in 4 Pieces | eBay
-Rich-
Old 09-28-2013, 11:38 AM   #26
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
The Dill TPMS is a intermal unit with all metal valve stems.Avalable at Tire Rack cheap and works good.
Old 09-28-2013, 11:43 AM   #27
W , New England
Thanks all,
You can get either. Just check their website.
Old 09-28-2013, 11:45 AM   #28
W , New England
The internal mounted TSTs I got we're attached to metal stems out of the box.
By the way - I sound like an ad for TST but I have no affiliation with them other than being a happy customer...
Old 09-28-2013, 05:49 PM   #29
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I mounted the Dill system 18 months ago when I went to the 16" wheels and Michelin LT's. It works perfectly, and after towing around 20,000 miles I couldn't be more satisfied.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-29-2013, 07:41 AM   #30
Ravenna , Ohio
Originally Posted by dznf0g View Post
Another vote for TPMS. I have Michelins on the AS, but this summer I had 3 valve stems fail during a 2 week period. Set aside potential AS damage, the TPMS saved 3 Michelin LTX M/S from being ruined by run flat. That's about $600 - $650 saved......more than double the cost of TPMS.
Did you report the valve failures to NHTSA? This is clearly a safety related failure of automotive part.
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
Tireman9 is offline   Reply With Quote
Old 09-29-2013, 07:46 AM   #31
Ravenna , Ohio
Originally Posted by kmaggard View Post
Any brand names recommended? Where is a good place to buy? You would need to have the tires rebalanced after install?
Two things I considered before buying my external TPMS.
1. Warranty (I have 3 years)
2. Replaceable batteries. ( I prefer spending $2 to spending $40)
Simple Google search then look at the details. Mine also give warning with both rapid and slow air leak.
Old 09-29-2013, 07:53 AM   #32
Ravenna , Ohio
I have seen valves at Camping World.
Meyers Tire Supply is possible
Google found
Gemplers
Anything Truck
and many more
Old 09-29-2013, 08:06 AM   #33
Ravenna , Ohio
I note a number of comments on sensors or extenders "flopping around".
Remember the standard low cost "snap-in" rubber valves are rated 60 psi MAX.
Rubber in valves ages like rubber in tires so you should ALWAYS replace the valve or rubber o-ring part of bolt in valves whenever you change tires.
Rubber valves are not designed to have stuff hung on the end so if you use either extenders or TPMS you should use bolt in metal valves.
I don't even think "high pressure" snap in rubber valves would be best with external TPMS.
I believe that most TT have passenger size valve holes not truck tire size valve holes so be sure you get the correct valve.
I have even written a few posts just on valves and others just on TPMS on my blog.
Old 09-29-2013, 08:21 AM   #34
"Cloudsplitter"
I guess there are +&- to all the various systems, internal sensors are most likely more accurate and reliable, but no replaceable batteries and they are transmitting even with the tires off, in the basement, for Winter storage.
(POI...in this regard, my OEM Burb sensors are 7yrs old and still going strong, maybe I will get around to installing the spares in the AS.)
External sensors can find legs and walk or get lost, but are more easily replaced, and removing can extend battery life.
ROBERT CROSS is online now   Reply With Quote
Old 09-29-2013, 08:39 AM   #35
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
My .02$.
I installed Dill internal sensors when I got the my tire issues a couple of years ago, for me works just fine. Only area that I'd ask Dill for an update on is the readout and its cumbersome mounting.
Hope to get 16's next year and I would get the Dill again.
Gary
GCinSC2 is offline   Reply With Quote
Old 09-29-2013, 11:10 AM   #36
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
We installed the Dill TPMS when we bought our trailer, two years ago. I mounted the TPMS display below the dash over the transmission hump. I mounted it in that location to keep it out of the sun. Bright sun light makes the display hard to read. Other wise the system has worked great.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 09-29-2013, 11:41 AM   #37
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Tireman9, Are these new to you?
1-1/4" High Pressure Snap In Tire Valve: AnythingTruck.com, Heavy Duty Truck & Trailer Parts and Light Duty Truck Accessories Warehouse
My EB has rubber stems and 80# max tire pressure on the Michelins,
And I thought I was done when I swapped out the bimetal lugnuts, , ,
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 09-29-2013, 03:23 PM   #38
dznf0g's Avatar
Oswego , Illinois
I didn't, I have no idea what brand.......just know the were installed by Discount Tire
-Rich-
Old 09-29-2013, 03:27 PM   #39
dznf0g's Avatar
Oswego , Illinois
Replaceable batteries in external mount sensors are known to leak water into them...as Robert says + & - to each kind. My Doran notifies both slow and rapid loss..the rapid loss notification is what I got with my stem failures.
-Rich-
Old 09-29-2013, 03:29 PM   #40
dznf0g's Avatar
Oswego , Illinois
Google found
Gemplers
Anything Truck
and many more
Again, be careful, the Sendel wheels have a small recess before you get to the mounting flange for the stem outer seal. A stem with a nut on the outside and one on the inside won't work. Not enough room for the nut in the recess.
-Rich-
Dill TPMS PJohnson Tires 21 02-03-2021 04:42 PM
Where can I buy a TPM system Castaway Tires 19 08-23-2016 07:47 AM
Which Dill TPMS sender unit for SenDel T03-66655T wheels switz Wheels, Hubs & Bearings 25 09-08-2015 09:43 PM
15" Wheels ednormandy Wheels, Hubs & Bearings 6 07-25-2013 09:55 AM
Tire Pressure Monitor Systems Bluto Tires 68 09-21-2011 06:59 PM
