Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 11-22-2015, 09:50 AM   #21
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Lost me at the Nitrogen.
Old 11-22-2015, 10:22 AM   #22
Refugee from Napa, CA
Photobum's Avatar
2015 25' Flying Cloud
Formerly Napa , On the road
theoretically they stay cooler with nitrogen...
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 11-22-2015, 10:48 AM   #23
Naples , Florida
Originally Posted by TheDuke View Post
For the best tire life, mileage, wear and over all performance, you should always run the max pressure listed on the sidewall. Tires that are underinflated run at hotter temps than tires that are inflated to max pressures. Many tires that blow out have usually been underinflated at some time in their life. Yes, you may notice a slight degradation in the ride, however you will have less sway and a better overall experience with your tire. For the best overall tire performance have nitrogen installed at max pressure. LT tires can even be inflated 10% over the sidewall max pressure per manufacturer specs for heavy hauling. I have never done so, because I never overload a tire, and I have never had any trouble.
Not wanting to troll this issue, but your source for this information, or your qualifications and/or certifications in the tire industry are…………..?
lewster
Old 11-22-2015, 11:04 AM   #24
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I run mine at 80 as recommended by Colonial Airstream. 12,000 miles so far and no signs of wear at all... certainly not the heavy center tread wear I'd associate with over inflation. This is a thought provoking discussion.
As for ride, there was that time we set up to camp and found a dinner fork in the ceiling that had been left on the breakfast table.... hmmmmm.
GammaDog is offline   Reply With Quote
Old 11-22-2015, 11:15 AM   #25
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Please, not nitrogen again....
2019 Ford Expedition Platinum
Old 11-22-2015, 11:34 AM   #26
"Cloudsplitter"
Thumbs up
I fill mine with compressed 'atmosphere'....then slowly let just the 21% that isn't N out.
Old 11-22-2015, 01:39 PM   #27
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Alright, so I ran 80psi. Inflated this morning, we drove for 2 hours from Parker, AZ to Yuma, AZ next to the proving grounds. 110 miles. I checked the PSI 75 miles into the trip with about 50 mins left. PSI had reached 89 psi in all tires. Ambient air temp outside was 71, but I am driving through the desert.
I can't tell if it was smoother or not honestly.
But I know where it wasn't smoother and perhaps worse. Washboard road! We drove 5 miles of washboard here to our spot in Yuma. 80psi might be fine on smooth US interstate, but I don't know about regular roads in the desert and dirt/gravel roads. That's really harsh.
So another question for this thread. When off-roading, I use my Staun tire deflators and take the truck down to 20psi. Nice, smooth ride. I would think this technique would work on the Airstream as well, since we are not on pavement, and traveling at very low speeds. Thoughts?
Probably wouldn't take the Airstream that low, but I might take it down to 35 or 40psi. Generally you want the tire to kind of look flat when off roading so it rolls over rocks and stuff easier.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-22-2015, 02:31 PM   #28
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Originally Posted by BoldAdventure View Post
If this is true, why then are manufacturers putting vehicles on lots with under inflated tires?
There seems to be no consensus or standard.
Manufacturers will list the recommended inflation pressure on door jam. You will find those PSIs, when checked against the tire inflation load chart, will match the tires to the axle max wt. My 2500 Chevy is fitted with "E" rated tires, yet door placard calls for front 60psi and rear 75psi. Those inflations bring the two tires equal to the axle certification on front and rear. Is called lawyer inflation pressure.
I run 75 to 80 psi on my ST Maxxis "15 inch E"s. I see no indication of rough ride to my 30 FC interior or exterior (and ST tires have a stiffer sidewall than the LTs that many now use). I would think for every pound you lower the pressure, the more safety margin lost. I also wonder how much air you have to let out to really get a ride smooth enough to matter. Sidewall pressure will give you the coolest running tire. Other than road hazards, or manufacturing defects, it's the heat build up that will park you on the side of the road.
Howard L. is offline   Reply With Quote
Old 11-22-2015, 02:41 PM   #29
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
With the Classic crossing the scales with about 8,160 pounds on the trailer axles, we run 75 psi in our 16" Michelins and temperature and pressure rise are fine even in the summer heat in the Southwest.
Old 11-22-2015, 03:26 PM   #30
1998 30' Excella 1000
Livingston , Texas
I would expect that when driven at low speeds on a smooth road your tires would do fine at a lower pressure. But if you are on a washboarded road, the dynamic forces will be much greater than a smooth road, and I would hesitate to drop the pressure below Michelin's inflation charts in order to baby the Airstream. If disturbed contents indicated a turbulent drive, I would just take those 5 miles a little slower.
Siegmann is offline   Reply With Quote
Old 11-22-2015, 07:01 PM   #31
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Why worry about temperature build up? An asphalt highway will be very warm and hold the heat from the sun, my original gyms have 21000 miles with 50 per cent tread left, checked a couple times a year kept at 65 lbs pressure, don't worry about the rest, My big truck steer tires are kept ay 120 lbs, after a 500 mile run on a hot summer day they are at 132 lbs pressure it is fine , everything is normal.....
Old 11-22-2015, 09:02 PM   #32
PKI
PKI's Avatar
Walnut Creek , California
At what rate do you let it out and do you use the left or right hand wrench with a pressure or volume gage? Pat
Old 11-22-2015, 09:53 PM   #33
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
To Their Benefit!
All automobile manufacturers list the inflation pressures that make their particular vehicle ride the best. They are not interested in making the tires give the longest service....haven't you noticed that they all sell tires? As for my experience, I grew up in a family owned trucking company, that had over 50 trucks! None of the Truck manufacturers list anything in the door jambs like auto company's do. I have also been towing RV's for more than 25 years, all shapes and sizes in all of the lower forty eight. No, I am not certified in the tire industry. I graduated from the school of "hard knocks!" That is where you have to use "common sense" and hard work to be successful. And yes, I have been self-employed all of my life and many would call me successful to have what I have and to be retired at 55 years of age. And no, I haven't inherited one cent! I made mine the old fashioned way...."I Earned IT!" Next?
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 11-23-2015, 04:05 AM   #34
Vintage Kin
Fort Worth , Texas
It's the forces on tandem axle trailers that themselves call for full sidewall pressure. Turns, curves, etc, are enough to subject the tire plies to tearing. Interply shear. Run full pressure and on to the next subject.
Old 11-23-2015, 04:23 AM   #35
CapriRacer
CapriRacer's Avatar
I'm in the , US
Don't forget the rule of thumb:
You want to see NO MORE than a 10% pressure build up.
If you see 15%, you need to fix that IMMEDIATELY - as in more pressure, a larger tire size, slowing down, etc.
If you are experiencing 10% to 15%, you DO have to fix it, but you don't have to do it right away.
Also, achieving a 10% pressure build up is NOT a goal. It is an indicator if something is wrong. This is NOT to say that everything is fine if you get less than 10% - It's that MORE than 10% is definitely a problem.
CapriRacer is offline   Reply With Quote
Old 11-23-2015, 06:34 AM   #36
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
BA, how fast were you driving?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Alphonse is offline   Reply With Quote
Old 11-23-2015, 07:24 AM   #37
dznf0g's Avatar
Oswego , Illinois
Do you need to account for ambient temperature rise when noting percent rise throughout the day? As well as sun load side of trailer?
I typically run less than 10% when temps are constant from morning cold start, but if the temp rises 20* by noon, I'll see a 9psi rise when starting at 80psi cold. Sometimes that's on the sun load side, sometimes not.
BTW, I have experimented with 70psi, 75psi and 80 psi. (70 is ok per weight and 15% margin with Mich LTX LTs). I have noted no difference in ride quality at 80psi, so I settled in there.
-Rich-
Old 11-23-2015, 08:14 AM   #38
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
"BTW, I have experimented with 70psi, 75psi and 80 psi. (70 is ok per weight and 15% margin with Mich LTX LTs). I have noted no difference in ride quality at 80psi, so I settled in there."
Rich, how are you measuring ride quality inside the trailer?
Doug and Cheryl
Old 11-23-2015, 08:24 AM   #39
Nomadic , USA
That seems to match my earlier statement:
I thought I read somewhere from Tireman6 or whatever his name is, that a tire's PSI shouldn't increase more than 5-8psi. If it's increasing by 10 or more psi then it's underinflated, overinflated or overloaded.
60 mph
Temperature has to play a role. When we were in Moab, I had my tires on the truck deflated to 33psi. We drove up to the LaSal Mountains where it snowed, and as the temp dropped my warning lights for low pressure came on because the TPS was reading the tires at 29psi.
So I can only stab at the wind here, and assume that ambient and maybe even the temperature of the pavement plays a role.
Old 11-23-2015, 08:57 AM   #40
dznf0g's Avatar
Oswego , Illinois
From prior posts in other threads, ambient temp is about 1 psi difference for every 10* change...but I don't recall the discussion relative to pressure rise (10% max) with any reference to ambients. I do recall that pavement temp was not considered significant with a rolling tire and airflow around it.
-Rich-
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin P235/75R15 LTX for use as a trailer tire?? Streamside Tires 50 03-28-2014 06:41 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
