Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 05-17-2011, 02:52 PM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
Wheel bearing size
I am going to pick up a new to me 75 Tradewind in the next week or two and I want to take a couple sets of new bearings with me just in case.
As per the service manual a tandum calls for the following:
LM67048 outer
25580 inner
42385 seal
I stopped by the local trailer shop and he has the bearings, but he says those numbers are for a 5000# axel. The serv.manual indicates the 25' Tradewind has a 2600# axel assembly. Being as the AS is 500 miles away I can't physically match them up. Would the 2600# axel have huge bearings as the book shows or am I missing something?
Thanks for the help.
Paul
Flynavy is offline   Reply With Quote
Old 05-17-2011, 03:13 PM   #2
LM67048 outer
25580 inner
42385 seal
Paul
Paul.
The bearing numbers are correct, but the number for the grease seal is for an el-cheapo seal.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-17-2011, 04:06 PM   #3
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Thanks for the reply Andy. The shop near me had a kit with the race and seal included, so I'm not sure about the seal. Why did AS use such a large bearing on a 2600# axel? Are the spindels all the same regardless of the axel size?
Old 05-17-2011, 04:37 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Because you have 12" brakes, they come with larger spindles than used on 10" brakes which are more common for that capacity axle.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 05-17-2011, 04:51 PM   #5
Tandem axle RV's, place tremendous stress on the tire, wheel and bearings when making a turn.
Cars and trucks don't have that same problem.
Simple answer is larger bearings.
Andy Rogozinski
Inland RV Center
Corona, CA
NEW: 5th Wheel Airstream Airtrekker Boondocking 43 05-30-2020 09:11 AM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 08:27 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
