05-11-2005, 06:15 AM
#181
Somewhere
, Indiana
Brett said it!
Originally Posted by thenewkid64
Let me start by saying I do not have a trailer with them, but I almost did. I wish I had bought it but it was back before the actibrake.
I see some big advantages.
1. Stopping power. Disc brakes offer a much improved capability to stop your rig when applied. In normal driving this may not be too much of an issue, but in a panic situation it could be the difference between a close call and a disaster. Of course the tires staying adhered to the road is a requirement, but as long as you do not lock them up, you will have shorter stopping distances.
2. Ease of maintenance. You have to remove your drum to check the wear on the shoes with traditional brakes. This means disturbing the bearings, and possibly the seal. On the Disc brakes you take off the wheel and check them. If you need to do pads, 2 pins and you can drop them in. There are even wear indicators just like on your car's brakes. And just like you cars brakes you can get parts at the local NAPA, vs having to go to a trailer supply store.
3. Fewer parts to maintain. A sealed caliper, and 2 brake pads, and a couple of pins. Compared to a drum brake with the springs, and adjusters, and magnets, less to go wrong. Also the Disc will be a better balanced rotating mass than the drum due to the fact the the cast piece is fully machined to a base spec. A drum is only machined on the inside, it can be out of balance and you may or may not be able to adjust for it.
4. If it was not a better braking system would the auto industry have moved to it over drum? I don't think so. The more expensive a car the higher likelihood that it will have 4 wheel Disc. Also If it was not a good system would the military Spec it out for their trailers. Of course they go with the stainless steel everything. Yes you can get stainless steel rotors, etc. They are made for the marine market.
5. If you are going to go to new axles, the upgrade to the Disc style is not the expensive. The controller costs a bit, but the wheel system is a minor upgrade as I understand it.
I could not have said it better!
I have one simple addition:
I am familiar with the Actibrake electric/hydraulic unit and Kodiak disc brakes. Honestly I would have to say that it has performed with great success on a delivery trailer used everyday. We replaced electric brakes 3-4 times a year, if that helps you understand the miles that this trailer sees. Once converted to Actibrake + disc brakes the trailer has needed repair only once in 1 1/2 years. The Actibrake was the problem, it was sent out, repaired for free and returned, it took about 3 days to get it back.
05-11-2005, 09:53 AM
#182
I know there are a lot of single axle Airstream and Argosy owners on here.
Some of them may be considering ordering their axle with disc brakes.
A couple of questions for the Axleman:
1. When would you consider using disc brakes on a smaller Airstream or Argosy?
2. What is needed to be housed in the trailer if you go with disc brakes?
3. What is the anatomy of a disc brake system?
4. Weight is an issue with the smaller Airstreams and Argosys. Do you need to add more weight to the trailer?
5. If you have to add equipment, how big is that equipment? Where would it go in the trailer?
6. Is there any additional wiring that would be needed?
7. What is involved in converting a drum brake system to a disc brake system?
Thanks for all of your wisdom!
05-11-2005, 10:37 AM
#183
Corona
Disc brakes.
We presently are making the disc brake conversions at the rate of almost two per week.
Disc brakes are superior to standard electric brakes on "any" size trailer, regardless of weight, for many reasons as Brett stated.
The actuator can easily be installed in the trailer, near the axles, either in an access compartment, or a closet. That also keeps it out of the weather.
Some additional wiring is necessary, but a detailed instruction manual is supplied with each actuator.
Conversion time on a tandem axle Airstream takes 10-12 hours, depending on the condition and floor plan of the trailer.
The initial cost for a disc brake system is much more than electric brakes. However, in time, far less repairs are required, and at a far less cost.
With the disc brake system, properly installed, using a top notch actuator, and controller, your rig will stop "ON A DIME".
Disc brakes will become, for many Airstream owners, a valued part of their lives, as it already has with cars and trucks.
They have become far more than "wait and see".
05-11-2005, 01:14 PM
#184
Somewhere
, Indiana
Lou,
You have asked good questions; let me do my best to address them in order.
- Q: When would you consider using disc brakes on a smaller Airstream or Argosy?
A: Disc brakes will better the braking on a coach of any size. - What is needed to be housed in the trailer if you go with disc brakes?
A: The electric/hydraulic power unit is the hot ticket today. This is typically installed on the tongue of the trailer. It senses the signal from the brake controller mounted in the tow vehicle and sends a message to a circuit board that activates a hydraulic pump to apply braking pressure. Another option, although not quite as common of a retrofit on Airstreams, is to use a hydraulic surge coupler in place of the standard ball coupler. When the tow vehicle applies its brakes it activates a master cylinder (similar to a car or truck) contained in the coupler and applies braking pressure to the trailer brakes. This works off of forward momentum.- Q: What is the anatomy of a disc brake system?
A: 1. Electric/hydraulic pump (such as the Actibrake) or surge coupler.
2. A brake like kit (contains fittings, tees, houses, mounting hardware, etc.).
3. Disc brake calipers.
4. Disc brake rotors (could be integral rotors or non-integral).
5. Brake Pads.
6. Brake fluid.
This would cover the basics.- Q: Weight is an issue with the smaller Airstreams and Argosys. Do you need to add more weight to the trailer?
A: Drum brakes are heavy. Thus, even with the addition of the electric/hydraulic unit or surge coupler it is pretty close to the same weight plus or minus a few pounds.- Q: If you have to add equipment, how big is that equipment? Where would it go in the trailer?
A: The only real addition is the electric/hydraulic unit or surge coupler and brake lines. Typically this equipment is tongue mounted, with the brake lines being routed to the wheels..- Q: Is there any additional wiring that would be needed?
A: No wiring is required with a surge coupler (nor is a brake control). For something like the Actibrake, wiring is required, see: www.activetech1.com/actibrak/brakesystem/install-man04.pdf- Q: What is involved in converting a drum brake system to a disc brake system?
A: In addition to electric/hydraulic unit or surge coupler, routing of brake lines, removal of old brakes and installation of the disc brakes. I have personally seen this job take a skilled technician about 6 hours for a single axle and I would plan on one 8 hour day for tandems.
Hopefully this will address your basic questions. Perhaps I have even included the “Wisdom” that you desired .
Henry
05-11-2005, 04:07 PM
#185
Henry
What the Axleman giveth so shall the Axleman taketh away!
Thanks for the professional insight.
I know that you are limited in your ability to quote prices but what I want to know is what is the average cost difference to go with disc brakes over drum brakes? Will anyone see any cost effectiveness by choosing disc brakes over drum brakes?
Thanks for your time, Henry! I am sure that this is all information that will help some decide which system to go with.
05-11-2005, 04:30 PM
#186
Corona
The cost of disc brakes over electric brakes, is obviously higher.
But the additional safety gained more than offsets the additional cost.
If not, then the auto manufacturers would not have switched to the discs.
Most owners that tow, have expressed the desire to having maximum safety
as primary and the cost of that safety to be far less than secondary.
All of our customers, so far, have asked "why not before?"
One of the good answers seems to be, "better late than never."
Justifying the additional cost certainly is up to each owner. But, most Airstream owners didn't blink an eye, when they found out the selling price of an Airstream.
Costs are relative.
Safety, is NOT!
05-11-2005, 04:55 PM
#187
Retired.
, At Large
If not, then the auto manufacturers would not have switched to the discs.Andy
Andy, do you know if anyone has experimented with an electric disc brake setup, that actuates in a similar manner to the drum brakes?
If one could be successfully, cheaply, and reliably, produced, it would be a simple matter to convert to electric disc. I visualize an electric, bi-directional motor mounted where the caliper piston is currently housed, with an auger type drive to apply the pads to the rotors. When you release the pedal, the motor would return to its "rest" position, and release the brakes.
05-11-2005, 05:01 PM
#188
Corona
Argosy 20
I have not heard of any such experiments.
It would appear to me, that the system you mentioned would have too many parts, compared to todays electrically activated hydraulic disc brakes.
Additionally, hydraulic disc brakes have more stopping power than electrics.
Disc brakes really cost about the same or a little more than electric brakes, but the large additional expense is for the actuator.
05-11-2005, 05:19 PM
#189
Disk brakes have superior resistance to heat fade.
The pads are easier to check than brake shoes.
But do not lose sight of the fact that Airstream specifies the bearings be repacked every year. The rotor is coming off anyway in spite of how easy it is to check the pads.
The Hydraulic pump is a single failure point which purely electric brakes do not have. It has its own maintenance issues which offset whatever 'ease of maintenance' bonus points highlighted by disk brakes.
Yes, everyone should have disk brakes. But get them because they offer a higher safery margin in off-nominal situations, and not because they appear to be easier to maintain than drum brakes.
Just another opinion from the Internet
05-11-2005, 05:25 PM
#190
They exist, but are still in development, and very high end.
http://www.airforums.com/forum...2&postcount=44
05-11-2005, 05:43 PM
#191
Retired.
, At Large
Originally Posted by markdoane
Yes, that is what I had in mind. Instead of having a hydraulic pump, brake lines, brake fluid, rubber hoses, etc. just have the same two wires actuating a self-releasing electric motor that has an auger to multiply the forces exerted by the electric motor.
05-11-2005, 07:10 PM
#192
Somewhere
, Indiana
Lou,
Perhaps Mike B. from Post #177 below would be willing to share his quote with all of you . He is doing a tandem axle conversion from disc to drum complete! This could serve as a base line for others (and there seem to be many) that are debating this as a possibility.
Additionally, while the Kodiak disc systems are new to Airstream and some others this year our Kodiak relationship and knowledge spans 7+ years. You see they are used heavily in the marine industry and for good reason. The 12-volt electrical system will experience limitations, as will cast-iron brake drums, when submerged in water, especially salt water .
I hope that this helps.
Regards,
Henry
05-11-2005, 07:19 PM
#193
Somewhere
, Indiana
Argosy 20
Andy,
Just a note: disc brakes do not have to actuate electronically, the surge coupler requires no wires, or brake control for that matter. When the tow vehicle applies the brakes the trailer continues forward, which activates a master cylinder contained in the coupler that applies braking pressure to a disc system (very much like stepping on your car brake pedal).
Regards,
Henry
05-11-2005, 07:40 PM
#194
Retired.
, At Large
Andy,
Regards,
Henry
Henry, I have used trailers with surge brakes, the brake part works very well, but on two different trailers, the coupler seemed to contribute to a sway problem on a travel trailer, and a pop-up trailer. Boat trailers and Uhaul trailers with surge brakes have worked well for me.
05-11-2005, 08:02 PM
#195
Somewhere
, Indiana
Terry,
That’s good information. I have learned so much from Airstream owners and this forum. I believe that there is no substitute for experience. You have obviously towed a lot of different trailers. I was simply pointing out that there is an alternative to the electric/hydraulic set up.
Thanks for sharing,
Henry
05-11-2005, 08:59 PM
#196
1977 23' Safari
1976 31' Sovereign
Robbins
axle prices
Originally Posted by Mike B
Hi All,
Henry and I spoke this morning and I firmed up exactly what I was going to order. Here is what I have ordered for a 1976 31' centerbath.
2)3700# torsion axle with camber, E coated
61.5" outside to outside mounting brackets, 80" hub face to hub face
High profile mounting brackets
22.5 degrees down starting angle torsion arms with shock mounts
12" Kodiak Disk brakes, E coated, 6 lug on 5.5" centers
Safe-T-Lube spindles
Actibrake electric over hydraulic brake activator
Brake line installation kit
Mounting bolts
Axis Products and Henry have been a real joy to work with and I would gladly suggest anyone who is thinking about replacing their axles give them the chance to quote you a price on your project.
Mike B
The prices for the above axles and parts are as follows.
2)Axles as described above $311.13 each, total $622.26
Mounting bolts $7.50
Brake line kit $100.00
Actibrake elec/hyd brake activator $500.00
Total cost less shipping or taxes $1229.76
I think this a very reasonable price for a high quality, state of the art axle with disk brakes and hardware package.
Mike B
Mike B
1977 23' Safari
1976 31' Sovereign
1996 F350 CC PSD
05-11-2005, 10:43 PM
#197
Mike B
Mike,
All I can say is, "HOLY CRAP!"
If the axles are "loaded" then the cost of the two axles, using Kodiak discs, is cheaper than buying ONE, (count it), ONE Henschen with DRUM brakes! Consider the fact that the Actibrake goes for about $250 more then what Henry quoted you and BAM! you got one heck of a good deal!
Man, am I glad that I went to Axis now that I see Henry and Eric treat EVERYONE like they treated me! Wait, now I feel "dissed".
Does that price for the axle alone include the disc brakes?
05-12-2005, 03:56 AM
#198
1977 23' Safari
1976 31' Sovereign
Robbins
Axle prices
Mike,
Lou ,
The above prices were complete axles hub to hub including the disk brakes. The prices with the disc versus drum were only about $75.00 more per axle as I recall.
I could not see not doing the disk now at that price, even with the added cost of the activator and mounting kit. This has pretty much blown my current budget allotment for fixing up the trailer for now, but I feel that since I plan on keeping it for a long time it is money well spent.
Mike B
Mike B
1977 23' Safari
1976 31' Sovereign
1996 F350 CC PSD
05-12-2005, 08:42 AM
#199
Lou ,
Mike B
Considering you paid over $300 LESS than getting two Henschen axles with drums and you got EVERYTHING I can see how you choose that route!
Good deal, buddy.
Please keep us posted as to how the installation goes. Take LOTS of step-by-step pictures for everyone on the forum!
05-12-2005, 08:43 AM
#200
Axle thingy I saw!
Hey, if you follow the Vintage Thunder blog you will now see that Axis Products is a proud sponsor of Vintage Thunder!
Good going Henry!
Keep up the good work Rich and crew!
