Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 12-13-2013, 05:51 PM   #1
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
New axle replacement
I recently installed new axles on our 1977 28' Argosy. After reviewing Inland RV and Colin Hyde axles, I went with Colin. My main reason was the plug and play installation (Henschen type mounting brackets). I took one measurement from the face of the brake drum to the mounting bracket, just for Colin to make sure I was getting the right ones. I also liked the fact that they are powder coated and are set up with safety lube spindles, allowing you to grease the bearings with out pulling everything apart. Shock brackets came welded on. I also went with 32 degree spindles to give it a little more clearance. With the help of a movers dolly, floor jack and a bottle jack I did the complete install by myself in 7 hours. The only difference was the shock mounting bracket was welded on the inside instead of the outside of the arm. I was told that the shoulder bolts came with the shocks and could be installed with the axles in place. I did not have quite enough room to install the shocks. So I cut the bolts to 2 3/8" total length and pried the bracket out away from the frame and installed the shock. The shock rides true, were the originals were 1/2" out of line. After installing the centramatic balancers and having the wheels powder coated, Every things looking good.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 12-16-2013, 11:37 AM   #2
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Would you mind posting a photo or photos of your shock brackets? I replaced my axles a couple of years ago and need to move the brackets a bit because of tire clearance issues going to a wider Michelin tire.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 12-16-2013, 07:27 PM   #3
1977 Argosy 28
Irrigon , Oregon
I sure will, but it will be this weekend so I can do it when it's light out.
Rod
AIR# 60278
Old 12-22-2013, 12:59 PM   #4
1977 Argosy 28
Irrigon , Oregon
pickerdd, Heres the pictures
Rod
AIR# 60278
