Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-18-2009, 12:04 PM   #1
Profile:  1962 19' Globetrotter
El Cajon , California
Axle mounting question - HELP!
I am preparing to install a new Henschen axle on my 1962 Globetrotter. Instead of cutting out the old axle from the bracket and side bolting the new bracket to the old bracket, can I cut out the old bracket from the frame, drill four holes through the bottom of the frame and bolt the new axle through the bottom of the frame? The bracket on the new axle has four holes pre-drilled in the top that I assume are for this purpose. My concern is weakening the frame rail by drilling the four holes. Has anyone done it this way?
Eric
sandfire is offline   Reply With Quote
Old 07-18-2009, 01:28 PM   #2
HansenClan's Avatar
Profile:  1965 26' Overlander
Encinitas , California
Images: 22
Eric,
I'm no Engineer, and not the smartest tool in the oven, but.... If you think about the trailer and it's weight, it is is designed to actually sit on the axle mounting bracket. So, unless your getting airborn in your Airstream, securing it to the frame does two things; 1) keeps the geometry of the suspension in the torsion arm and/or shocks (if you have them) in line, and 2) keeps the axles attached to the trailer, also again, in line.. There are two types of strengths to consider, shear and tension. Tension pulls in a straight line, with say, the bolt, and shear pulls perpendicular to the bolt. Shear is stronger, and that is why they are mounted through the side of the frame rail. That puts the bolts in shear vs tension. Plus it makes it easier to access, if you need to replace them...
Hope that helps..
p.s. no comments from the peanut galleries, I disclosed I am NO Guiness... :-) CHEERS!
HansenClan is offline   Reply With Quote
Old 07-18-2009, 01:43 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Why weren't the axles supplied to mount the same as the originals?
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-18-2009, 01:54 PM   #4
The original axle bracket is welded to the bottom of the frame rail and the axle is welded into it. I understand shear strength being stronger, so I am going to go ahead and bolt the new bracket sideways into the old bracket. I was just trying to consider something that did not require a cutting torch. Thanks for the input!
Old 07-18-2009, 02:46 PM   #5
Commercial Vendor
Profile:  Corona , California
Thats the best way to mount a new axle on an old chassis.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-18-2009, 02:41 PM   #6
Commercial Vendor
Nobody has a bracket that fits the old, old, old, old trailers.
Andy Rogozinski
Inland RV Center
Corona, CA
Vintage Rock Guard Mounting Question toddster Rock Guards, Segment & Window Protectors 2 03-31-2009 12:59 PM
LCD TV Mounting Bracket - One More Question flyfisher Audio, Video & TV 98 04-27-2008 10:32 AM
Axle Question drex Axles 7 07-30-2007 06:50 PM
Another axle question wannaroam Axles 16 10-12-2006 09:17 AM
Axle mounting bolt size? Bryanhu Axles 11 10-11-2003 09:20 PM
