Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-12-2016, 03:18 PM   #1
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Upgrading Penguin Duo-therm controller
I have a 2008 Penguin Dou-Therm AC and older 5-button controller (picture attached). Would like to upgrade to the CCC2 controller found in newer units.
Emailed dometic and they told me this is not possible. I asked if I could swap out the control unit and they told me no, not possible.
Just curious if others have managed to make the upgrade...
wulfraat is offline   Reply With Quote
Old 07-14-2016, 05:58 PM   #2
wulfraat's Avatar
Bump!
Old 07-14-2016, 06:06 PM   #3
Naples , Florida
You can retro-fit a new unit with a 5-button control board that makes the Penguin II reverse compatible with the CCC-1 (assuming that the boards are still available) as I have done it several times, but you can't fit the new control board to an older Penguin A/C unit to allow you to upgrade to the CCC-II.
Dometic is correct (as they should be....... It's their stuff..... They SHOULD know how it works!!!)
lewster
Old 07-14-2016, 06:09 PM   #4
wulfraat's Avatar
Thanks for the confirmation Lewster!
Boooooo Dometic!
Duo-Therm Penguin A/C cooney Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-22-2008 07:55 PM
Dometic Duo Therm Penguin gloran Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-20-2007 11:06 AM
Need Dometic Duo Therm Penguin air distribution box gloran Land Yacht/Legacy Motorhomes 1 01-20-2007 11:00 AM
Duo-Therm Penguin odor startrekker2001 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-22-2003 08:49 AM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
