Old 03-01-2014, 11:48 PM   #1
1968 26' Overlander
Eugene , Oregon
Suburban NT-30SP Replacing NT-22A
Tracker Inspired me! Many thanks for posting picks and giving me a point of reference. Doing this myself certainly save some $$$.
I took the plunge and bought a new Suburban NT-30sp to replace my Nt-22a found in my 68 Overlander International. I did a few things different than Tracker, but followed his lead, and.... who knows might burn down my trailer....... so Somebody please let me know if you see anything I've done that is of concern!!!
To start, I cut out the containment box of the original NT-22A. Started cutting with tin snips, and resorted to saw-zall to remove the sides. Then cut back the bottom to the length that corresponds with the inside back edge of the bottom duct opening in the new heater.
http://www.qsterry.com/wp-content/up.../IMG_60191.jpg
Then I cut 3/4" plywood, hacked out slots for the rails to fit, and fastened it to the metal box.
http://www.qsterry.com/wp-content/up.../IMG_60211.jpg
Then wrapped the font edge with galvanized flashing I had laying around. As you can see I was liberal with some real "Duct" tape I also had lying around.
http://www.qsterry.com/wp-content/up.../IMG_60221.jpg
Had to get a little creative in closing the rest of the shroud opening, so I used the steel box from the NT-22A that I had just cut out with the saw-zall and used tin snips to cut a closing steel shroud that would mate up with new NT-30sp.
http://www.qsterry.com/wp-content/up.../IMG_60241.jpg
http://www.qsterry.com/wp-content/up.../IMG_60251.jpg
http://www.qsterry.com/wp-content/up.../IMG_60261.jpg
The final shroud matched up pretty nicely!!! First try!
http://www.qsterry.com/wp-content/up.../IMG_60281.jpg
Test fit and things seem to line up!!
http://www.qsterry.com/wp-content/up.../IMG_60291.jpg
Finished the seal between the new heater and shroud with 1/2" fire safe rope and closed the circular side vents with galvanized sheet flashing both items waiting to be used. (One of the few times in my life I've been rewarded for being a pack-rat , and will help to perpetuate this terrible habit)
The Final product almost looks professional!
http://www.qsterry.com/wp-content/up.../IMG_60361.jpg
I must confess that the existing vent lines thru the skin needed to be modified a tad to work with this new position, and for some damn reason the new vent cover on the outside turned out a little crooked, (not exactly vertical). It is almost like the new header box was a little skewed, but it was probably the metal shroud's position relative to skin. Either way I know it's watertight, and..... Wait for it.....
I HAVE HEAT!!!!!
Quince is offline   Reply With Quote
Old 03-02-2014, 08:00 PM   #2
Ottawa , ON
Lookin' good, Quince! And as you say, the best part is you have heat!
If you want to see how I did that exact same job, have a look at post #165 in my thread. This ink should take you right to it.
I did many things the same, but I didn't use any wood at all. I planned it so that the exhaust holes would line up with the furnace's hot-air outlet and fresh air input.
Good work!
Aage
Old 08-10-2021, 11:13 AM   #3
1973 Argosy 26
friday harbor , Washington
Kinda related to this thread, but wondering if anyone has swapped out an old NT 22C (from a '73 Argosy 26') with a new NT 20SQ? Cabinet on the NT-20S is smaller, and BTU isn't that much less (19,000) than what my current NT 22C produces (22,000). Also, I only have two ducts anyway, and not looking to add anymore, so for my purposes, I think the NT 30 is overkill. Thoughts?
copargosy26 is offline   Reply With Quote
Suburban NT-30SP Won't Stay Lit crabbey1 LP Gas, Piping, Tanks & Regulators 9 10-03-2013 06:48 PM
Best place to buy a Suburban NT-30SP furnace? Astrodokk Classic Motorhomes 3 03-08-2013 06:20 PM
Pix of Suburban NT-30sp replacing NT22 fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 29 02-24-2012 01:46 PM
Suburban nt-30SP will not start bmccomb Furnaces, Heaters, Fireplaces & Air Conditioning 46 01-15-2012 08:42 AM
Suburban NT-30SP installation tip Starscream Furnaces, Heaters, Fireplaces & Air Conditioning 7 10-25-2010 04:01 AM
