Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-29-2005, 08:39 AM   #1
BURNZEE
Profile:
sealant @ Furnace vent cap
Hi all,
Finishing the replacment of a new suburban furnace in my 66 safari. Is it OK to use Velkum at the exterior vent cap. Install instructions don't specify which type.
Thanks for the help. A/C is next.
BURNZEE is offline   Reply With Quote
Old 04-29-2005, 08:54 AM   #2
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
I actually called Suburban tech support when I was re-installing my original furnace. I was actually looking for replacement parts, but while I had them on the phone, I asked the same question. The guy told me that any urethane sealant would be fine, as that spot doesn't actually get all that hot. your "new" furnace might be a different situation, though...main point is that you can call them and ask.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-29-2005, 09:53 AM   #3
BURNZEE
Profile:
Thanks Chuck,
Heat was my main concern. It seems like the heat resistant stuff is usually silicone (a big no no ) Thanks for the response.
Old 04-29-2005, 11:54 AM   #4
sfixx
Old Paint, rolling again.
sfixx's Avatar
Profile:  1973 Argosy 20
Lorain County , Ohio
Images: 13
caulk talk
Originally Posted by BURNZEE
...Heat was my main concern.
I don't know about Vulcum but Sikaflex-221 has pretty good heat characteristics: up to 355 degrees for 1 hour and 320 for 4 hours constant.(See attached PDF) How hot do you think that the exhaust gets?
I bought some Vulcum after using up my first tube of Sikaflex-221 and didn't like it as much. It seemed to dry a lot slower and didn't have as much initial tack.
Now I'm using Sikaflex 295 on my windows where the weather stripping has hardened and it's working really well.
Good luck,
Steve
Have you never questioned those who travel?
Have you paid no regard to their accounts- Job 21:29
Fixxer's Argosy Resto-Blog
Courtesy Parking: 15 minutes off the Ohio Turnpike West of Cleveland... W/30 amp/water+WIFI ...The Next Best Thing to Larry and Lou's TM
sfixx is offline   Reply With Quote
Old 04-29-2005, 01:27 PM   #5
BURNZEE
Profile:
Thanks Steve,
If it gets hotter than that I'll have other things to worry about besides the exterior sealant. I've actually got a tube of 221 but haven't opened it yet. Been using Velkum 636, but just ran out. You mean I've got just what I need,, that never happens. Thanks
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 11:00 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
test
