Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 09-12-2010, 06:22 PM   #1
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Ready to purchase AC unit. Need input.
I am ready to purchase a new air conditioner for my 1958 Flying Cloud. I removed the rat infested factory original and gave it the old heave ho off the roof.
Those of you that have bought AC units in the last five years, if you could do it again, would you buy the same unit or get something else and why. They are all generally about the same price, I do want a low profile one, which may limit my choices, but still want to hear of brands or models to avoid.
Thanks!
Matt
ddstech is offline   Reply With Quote
Old 09-14-2010, 03:55 AM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I got a Carrier low profile for my former Airstream and had absolutely no problems with it during two years of regular use. It was a 13.5k model, and was quiet, with no vibration, unlike some I have seen. I would buy again.
TX-16
Dave Park is offline   Reply With Quote
Old 09-14-2010, 05:23 AM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Here's a thread about my daughter's problems with a BRAND NEW Dometic Penguin Low Profile
http://www.airforums.com/forums/f427/help-im-roasting-67933.html
Bad customer service, not well trained techs
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-14-2010, 05:36 AM   #4
Kevin245's Avatar
Carrier has a good reputation but reportedly they dropped their RV line. There are some units still on the market but availability is scarce. Parts shouldn't be an issue for the foreseeable future but eventually those resources will dry up.
If I were in the market and found one to buy I wouldn't hesitate to snatch it up.
Regards,
Kevin
William C. Swinney
Old 09-14-2010, 07:01 AM   #5
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
I too would not consider Dometic. I installed a new 15k Penguin last fall on a 53 Flying Cloud. The first unit had a bad compressor, it would run for a few minutes then start violently vibrating and at that point the amperage draw would start climbing from around 12 to over 17 at which point I would shut it down. Dometic warrantied it because the compressor was trying to seize. Then comes the replacement unit. Install it, it runs well, amperage draw is within specs. But, after it cools for about 10 minutes or so the evaporator coil begins to ice up at which the thermal switch would shut down the compressor and thus end any cooling. After many hours of diagnosis on the phone with Dometic they warranty that unit out, though they could never figure out why it was acting up. Now I wouldn't trust one to come out of the box and operate as it should.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 09-14-2010, 07:17 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Ditto on the above - with just the fan running you can't even hear it 10 feet from the trailer. We purchased here: FAMILY RV CENTER ll - Home
I talked to this dealer a couple weeks ago about Carrier exiting the line - they said a deal was in the works to sell the unit to another company that would contiue to build them.... that's their side of it anyway....
Old 09-14-2010, 08:41 AM   #7
LHall's Avatar
2020 30’ Globetrotter
2001 30' Excella
Phoenix , Arizona
We installed a Carrier Low Profile 13.5 and have been happy with it for the two years we have been using it. The only thing I must say is that you have to ensure the filters are clean, the smallest amount of dirt will cause it to freeze up. Otherwise it works great.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 09-14-2010, 08:54 AM   #8
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I bought Carrier 15K low profile also. Can't report on how good or bad it is since I haven't turned it on yet. Upper unit is installed and looks much better than the old Armstrong!
SilverHoot is offline   Reply With Quote
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
Getting Ready to Purchase gandttimes General Repair Forum 9 10-05-2004 04:22 PM
A/C unit size input.... Silvertwinkie Our Community 4 09-04-2003 06:05 AM
