Old 09-03-2009, 06:09 AM   #1
Engtech05's Avatar
1969 31' Sovereign
Katy , Texas
New Shroud for AC
When I bought my '69 AS it didn't have the bigger AC shroud around the AC unit. Then on my way to AR for a wedding the only remaining cover blew some where down the road. Ugh!
So through some contacts at te local marina I was able to acquire some of the styrofoam they use for floating docks and such. The next part was more of an experiment than anything else, I had to measure twice cut even more times just to make sure I was close to the original as possible. I then had to look online for the how to on fiberglassing. Little did I know that fiberglass resin will eat styrofoam, back tot he internet. Ah, Ha!!!!
To use styrofoam you have have a medium that will not melt, solution wax paper. So, I covered the mold and went to work, albeit not the best looking thing but it works for what I needed.
Round two: Looking online for the bigger shroud and finding it cost way out of my price range I decided to make another mold. Back to the marina, bad news they had some foam but it was to small, ugh. Another source down the road had the huge pieces, my luck held the owner was giving these away. The piece I got was 1 foot thick, 5 feet long, and 4 feet wide. I had to figure how to cut this piece down to size. Chain saw works like cutting butter with a hot knife. After the rough cut and some major smoothing the final piece looks like this.
Next post: Fiber glassing.
ID:	86564   Click image for larger version
Gary
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
Engtech05 is offline   Reply With Quote
Old 09-03-2009, 06:14 AM   #2
StingrayL82's Avatar
San Angelo , Texas
Images: 37
The ingenuity people display on this forum never ceases to amaze me. Good job, Gary! Keep the pics coming.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-03-2009, 07:04 AM   #3
Engtech05's Avatar
1969 31' Sovereign
Katy , Texas
Fiberglassing
Ok, I am glad of one thing, I did all of this outside, the mess was amazing little foam balls everywhere. But I digress.
After some more smoothing and checking of the positions for the vents on the side I covered the mold in wax paper.
I thought I would use two types of fiberglass (mat and cloth) as well as two different types of resin (jelly and rosin).
After using the jelly i have decided that this stuff is good for filling large gaps and cracks or maybe as a final application. So I stayed with the regular resin. After several layers of fiberglass mat and two layers of cloth the shroud looks like something I can use. In the first two photos I have lifted it off mold to check the interior for cracks or spots that were devoid of resin.Click image for larger version
ID:	86567 These next two are of the shroud off the mold and have been sanded and are ready for the first coat of Primer.Click image for larger version
ID:	86568Click image for larger version
Gary
Henry Ford
Old 09-03-2009, 07:07 AM   #4
Engtech05's Avatar
1969 31' Sovereign
Katy , Texas
Primer
Here is the Shroud with three coats of primer, as you can see I just used regular spray paint nothing to fancy.
Gary
Henry Ford
Old 09-03-2009, 07:14 AM   #5
Engtech05's Avatar
1969 31' Sovereign
Katy , Texas
I have to get the photos of the final paint job. I also had to create, make the "Z" channel for the shroud to be attached to. (Thanks to TomW for the photos he provided when he was restoring his Overlander.) I have since then plae the shroud on the AS and it is about 4 inches to long in the back but I think it it is ok. It doesn't have the nice curved edge that the one you can does but I placed an edge guard around the shroud so it doesn't sratch the aluminum.
Gary
Henry Ford
Old 09-03-2009, 09:50 AM   #6
San Angelo , Texas
Images: 37
Gary, you might want to keep the mold...people might ask you to make one for them, especially if you can do it cheaper than what it's being sold for elsewhere.
If it weren't for the fact that my shroud is 100% intact, I'd wonder if a 1969 shroud fits on a 1971. You do have an Armstrong A/C, right? Ever notice that the shrouds look different from year to year?
Great job!
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 09-03-2009, 02:34 PM   #7
Engtech05's Avatar
1969 31' Sovereign
Katy , Texas
I made sure I kept the mold for just such an occasion if such a need ever arises.
Supposedly this mold will fit 64-69, according to my sources. And yes it is an Armstrong.
Gary
Henry Ford
Old 09-03-2009, 02:46 PM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
How many layers of mat and cloth? How thick did your shroud end up being? Got a picture of the final installation?
Pretty cool btw!
Chris
Old 09-03-2009, 03:11 PM   #9
Engtech05's Avatar
1969 31' Sovereign
Katy , Texas
I used two layers of each with the cloth being the final layer. I will have to post a pic when I get back to the house. I'm in the middle of the 30 mile yardsale, have to finance the AS projects somehow, 5 years of collected stuff going to the highest bidder.
I will try and get the finished photos up in a couple of days, the thickness is approx 1/16+/-. I tried to make sure that the wind side was thicker that the rest that way road object will not break through.
Gary
Henry Ford
New a/c shroud!! Chas Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-31-2016 03:26 PM
AC Shroud Help stoney1939 1965 - 1969 Overlander 5 08-17-2014 05:23 AM
Shroud Necessary?? The Flintstones Furnaces, Heaters, Fireplaces & Air Conditioning 11 06-07-2009 05:15 PM
ac shroud rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 11 03-12-2006 11:34 AM
