After my MH sat for 5 years, I was sure it would be growing mold. Turns out it wasn't, just some surface mildew that wiped off with Lysol wipes, but I purchased a Ozone Generator.
Something about ozone kills odors, they use it in rehabbing homes after fires and smokers.
You can't stay inside with the ozone, but you can air it out and return right away.
The ozone generator is basically a box with a fan on one end, electrical plates in the middle, and a timer on the other end.
Also, you might remove the AC shroud, spray some tub and tile cleaner in the pan (Bleach), I know my home ac builds up rainwater and gets algae that clogs the drain.
