Old 08-07-2008, 08:09 PM   #1
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
It's dead Jim.
Bones can't you revive it. I am afraid not Jim.
It is official. I killed my first appliance. After concurring with Doug at AS of Spokane my unit is dead. When the compressor tries to start the voltage drops to 98 and the Amps climb to 28. At least that what I could measure. Inside a funny warm electronic smell. That confirmed it.
I stop back by Tuesday to have the unit replaced/upgraded. I had him order a 15,000 BTU unit instated of 13,500. It comes with the hard start kit. The bed room was taking a long time to cool down.
The cost around $1400 for the unit plus install. Better than replacing the house unit!
Michelle TAC MT-0
Sarah, Snowball
Old 08-07-2008, 08:21 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Out of warranty?
I guess nothing lasts forever. Have you considered the low profile 15k units? I see them for much less than 1400.00 all day long. Just wondering...
Anyways, good luck, Michelle, and stay cool!
We have family in Billings, btw. I like the wide open spaces up there. How's the riding in Montana? My R1100 just turned over 72000mls.
Uwe
www.area63productions.com
Old 08-07-2008, 08:34 PM   #3
Agree with Uwe, $1400 seems high.
It's really not that much work. I just ordered a Carrier low-profile 15K BTU + heat strip for $750 delivered, and the work is DIY-friendly, especially if you have a couple of friends. But even if you have an installer do it, I can't imagine them charging another $700 for the install-- at $100/hour, that's 7 hours, and I don't believe a pro would take 7 hours to do this job...
Old 08-07-2008, 08:48 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Michelle,
I purchased a 15K low profile Carrier with heat strip for much less than $1400 last month. My son and I installed it on our Liner.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 08-07-2008, 09:17 PM   #5
Naples , Florida
Michelle,
Are you in your 3rd year of warranty? If so, the replacement of your roof air is covered by Dometic's 3 year warranty..............but only the parts. Also, Dometic will only replace exactly what you have...as in 13.5K.
But If I were doing the job, I would get your replacement unit from Dometic and take it in trade for the 15K that you want ....plus a few bucks!
IIRC, a new 13.5K heat pump Penguin has an MSRP of around $900, and the 15K is just a bit more......maybe $1050 plus freight. Are you replacing the lower unit as well, or just the topper?
Also, usually takes me between 1-1.5 hrs to do a 'normal' roof air replacement....but as you know.........Airstreams are anything but 'normal! I would go with 2-2.5 for the job, considering they have to deal with the drain pan. Plus, if I were doing it, I would remove the drain pan completely and go with Dometic's auxiliary drip kit, which gives you little cups to catch the condensate, a drain hose arrangement and a second gasket for the unit. It would work fine on your Classic's roof, which is a little bit wider and flatter than the rest of the A/S line. Don't know why A/S doesn't do this to begin with, as almost all of the high end MoHo OEMs use the drip kit!
Good luck!
lewster
Old 08-07-2008, 09:39 PM   #6
Originally Posted by uwe View Post
Out of warranty?
I am past my two years on my trailer. are you telling me my AC has a three year warranty? Wooo hooo I am upgrading to the 15K unit.
It should have said $1400 installed. including a new pan three day freight from Jackson Center.
I have riden Ruby from Missoula to La Grande and done a few rides around La Grande. She will be coming hopefully with me to Helena?
I have put 1500 miles on her so far.
Michelle TAC MT-0
Sarah, Snowball
Old 08-07-2008, 09:42 PM   #7
The replacement unit is around $900, four hours of labor at $70/hour and a new pan for about $100 plus freight for the pan. A little less than $1400. If I had my own place I would do it my self. I need it done quick. It is hot and they can do it on my way back to La Grande.
Michelle TAC MT-0
Sarah, Snowball
Old 08-07-2008, 09:46 PM   #8
Originally Posted by lewster View Post
Michelle,
I am in my third year of ownership. I am getting the 15K unit. My understanding the whole unit is getting replaced.
I will bring that up with Doug.
Good luck![/quote]
Michelle TAC MT-0
Sarah, Snowball
Old 08-07-2008, 10:40 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I kinda think that $ 1400.00 installed, with express freight and a pan is somewhat reasonable. Put in perspective, Thanks.
Sheesh...only 1500 miles? Not even really broken in yet. It's summer, Michelle! Get out there!
Uwe
Old 08-08-2008, 06:45 PM   #10
Retired.
. , At Large
you started it...
Michelle, you know you have to realign the dilithium crystals to the primary power couplings through the antimatter inducer, or else the ODM conduits will suffer a cascade failure, resulting in the artificial gravity plating to the phase coils inverting.
Old 08-08-2008, 07:05 PM   #11
I have only put 1500 miles on it and that was in about a month. We were separated for a couple of months. It had 15222 on it when I bought it. It still looks brand new. She is three years old.
Michelle TAC MT-0
Sarah, Snowball
Old 08-08-2008, 07:06 PM   #12
I'm not the Chief Engineer. I'm a doctor Jim! I only have a tricorder.
Michelle TAC MT-0
Sarah, Snowball
Old 08-08-2008, 07:13 PM   #13
richinny's Avatar
2011 34' Classic
illogical
Ricky
Old 08-08-2008, 07:17 PM   #14
Retired.
. , At Large
Ach! Me Bairns!
Old 08-08-2008, 08:01 PM   #15
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
After reading all this - "beam me up, Scotty" - "There is no intelligent life down here......"
Michelle, it's good to hear you are still at it. Keep up the posts.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-08-2008, 08:16 PM   #16
Naples , Florida
Can I please stop laughing now........PLEASE
lewster
Old 08-08-2008, 08:50 PM   #17
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Ach! Me Bairns!
"Jim! his brain is gone!"
ArtStream is offline   Reply With Quote
Old 08-08-2008, 10:33 PM   #18
_
"nothing unreal exists"
only nixon can travel to china and only a mind meld will solve this crisis.
"my mind to your mind...my thoughts to your thoughts..."
cheers
2air'
Old 08-18-2008, 09:54 PM   #19
Jim,
I revived it with a brain transplant. THat's great bones!
It turns out I already had a 15,000 BTU unit. I still have the old style air box on the bottom. Doug completed the whole thing in a couple of hours. I was fortunate the weather was cool at night and i could sleep. It was over 100 here yesterday. I was happy to have the new unit.
Michelle TAC MT-0
Sarah, Snowball
Jim Anderson jjanderson5 Member Introductions 2 05-26-2008 11:19 AM
Jim G. Harper Member Introductions 2 04-13-2008 02:26 PM
jim t jim turcato Member Introductions 4 03-11-2008 08:17 PM
jim jamesnolan75 Member Introductions 2 09-09-2007 10:46 PM
Now is your Chance to tell Jim where to go Jim Clark Off Topic Forum 39 05-25-2006 04:55 PM
