Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 01-30-2007, 04:58 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Heatpump vs. Standard AC
I'm trying to decide on an AC for the Ambassador.
I could either go with the heatpump that is also a 13.5kbtu air conditioner. The heatpump will provide heating to around 40 degrees outside.
Or I can go with the 15kbtu with a heatstrip.
Is the extra 1500btu worth it over not having the heatpump? Or should I go with the heatpump so I can save on propane when we have full hookups?
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 01-30-2007, 06:01 PM   #2
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
Tim,
We went with the 15K BTU unit in the 28' because we live in AZ. I believe ours also has the heatpump as we have the digital wall thermostat with different modes. We do a lot of winter camping and have not used the heatpump (yet). If you're planning on visiting the southwest in the summer you may want the 15K unit for the 28'.
-KL
4CU Charter Member
1981 Excella 280 Turbo Diesel Motorhome
silverback is offline   Reply With Quote
Old 01-30-2007, 06:04 PM   #3
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
I have the heat pump. It works great until you really need heat, then it just blows cold air. I would say get the electric strips. The other side of the coin is you need to run the furnace some to keep plumbing and tanks from freezing in the belly pan. I have made that mistake too. Live and learn.
Jeff & Cindy
Remi & Hunter
'81 International 31'CB
WBCCI #7026 Air #17054
"Fus-A-Lodge"
Old 01-30-2007, 06:06 PM   #4
str8strm's Avatar
Profile:  Tujunga , California
apples and oranges
the heat strip on our AC does not do much, I think you feel cooler with all the air circulation!! We have furnaces in the MoHo and ran them almost non stop (for the first time) at the 29 palms rally earlier this month---it got down to 18 degrees. We would not have done well with only the heat strips. Of course we were on full hookups and could have used a small space heater to augment the heat strips. As noted above the furnaces kept all the internal plumbing from freezing, our outside hoses froze the first night so we went to using tank water.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 01-30-2007, 06:15 PM   #5
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I have a Carrier heat pump for our house, (60,000 BTU) It kept our house warm last night down to 25*F. It has a built in 5 KW heat strip, but we seldom use it.
The heat strip in our Coleman really doesn't provide much heat at all.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 01-30-2007, 06:24 PM   #6
SafariSS's Avatar
Profile:  2005 30' Safari
Houston Texas , Texas
We have the Heat Pump...
I have a DuoTherm(Dometic) 15k AC w/heat pump. I have found the heat pump to work ok down to about 45F. My main thing is I dont like the condensation that it produces when running in heat pump mode as I like to keep the outside of the trailer clean! During AC mode the condensate runs out the little tube in the wheel well.
Does anyone know if running the Heat Pump down really cold will cause icing on the condensor?
SafariSS is offline   Reply With Quote
Old 01-30-2007, 07:01 PM   #7
Moderator Emeritus
Pick's Avatar
Images: 36
Yep! It does! My home unit has a "defrost mode". Actually all it does is go back to normal air conditioning mode for a few minutes to clear the ice off.
Lots of Hot Sauce!
Air # 283
Old 01-30-2007, 07:04 PM   #8
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
I also have the 15k A/C with heat pump. I use both and for a 28' Airstream, heat pump issue aside, 15k is the smallest you want to go with. I know some folks will disagree, but back when it was not common, I special ordered our unit with it. Today, many of the 27' footers commonly have it. It does cool very well, even in direct sunlight, or at least it does on my 25' Safari.
I recall several folks trying to talk me out of it, even some folks at the dealer. They said:
"It's only 25' and it's not a standard option for the Safari."
I said "I know and if it's an option for the 25' Classic which has the same specs, then it's good enough for the Safari."
One of the best additions to my Airstream I made, right next to getting the second Fantastic Vent.
Dry heat, humid heat, it doesn't cycle as much as folks said it would and cools perfectly....those who see me at the Midwest Rally know I can get it cold enough to hang meat inside.
Old 01-30-2007, 08:26 PM   #9
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
A/C in Reverse
That's how heat pumps work. There is a reversing valve in the suction line that reverses the flow of refrigerant to turn the evaporator into the condensor, and the condensor into the evaporator. This causes the usually warm air that gets discharged from the condensor to the outside to flow across the evaporator and then into the trailer.
They are not very efficient below 50* and just don't seem to throw much heat at that temp or below. Neither will a heat strip. The furnace is noisey, but it will surely give you the most bang for the buck, considering the much larger transfer of BTUs that they will produce.
That said, the heat pump WILL take the chill out of a cool-ish morning without running the furnace and it's associated noise....and they are only about another $100 or so over the standard A/C unit.
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
Old 01-30-2007, 09:18 PM   #10
Safari Tim's Avatar
Images: 35
Cool. For some reason I thought the heatpumps only went up to 13.5kbtu.
So it looks like the 15kbtu with heatpump is the way to go then. No downside to the heatpump?
-Tim
Old 01-30-2007, 09:20 PM   #11
Aluminut
Not unless it gets under 50 degrees outside. Like Airstreams and tow vehicles, few downgrade.
Old 01-31-2007, 05:29 AM   #12
2toomany's Avatar
Profile:  1973 23' Safari
1963 19' Globetrotter
Forest , Mississippi
carrier 15kbtu
Only from my past experience with a carrier 15kbtu mounted on a 73 safari camping in the southeast, winters are very mild but offer great camping weather. The carrier will keep you warm to about 38 degrees and will still work below that but, the temp in the trailer will also start to decrease, this is where your furnace or alternate heat source is helpful. Very rarely do we ever camp for extended amounts of time below 38 degrees, but there again it rarely gets below 38 on a continious basis in the southeast. Hope this is helpful
2toomany is offline   Reply With Quote
Old 01-31-2007, 07:05 AM   #13
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
I keep hearing that heat pumps don't work under all kinds of temperatures; 40, 45, etc., even 50 degrees according to Silvertwinkie.
It's odd that this morning, in the mid-30s, I had to turn the thermostat down a bit because it was too hot in the trailer. I had it set at 72 and it was cycling, so I turned it down to 69.
In 4 years of owning heat pump-equipped Airstreams, I have only had the furnace switchover occur about three times and, those times, I also had frozen water hoses.
The output from a heat pump is not very hot, but it is warmer than the intake air and will keep the trailer plenty warm. While I use a ceramic heater to help initially warm the cold-soaked trailer, the heat pump keeps the trailer warm to near freezing.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 01-31-2007, 07:21 AM   #14
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
Our 13.5k heat pump works great for us. We use it almost exclusively to heat Lucy. We have camped in Lucy with nights in the 30's for about 30 nights, and have found that the heat pump is all we need.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
New Carrier A/C Heatpump Silverhobby Airstream "In the News" 1 01-27-2008 06:00 AM
what type of converter is standard in 85 limited jlsmits Electrical - Systems, Generators, Batteries & Solar 2 07-20-2006 09:54 PM
Is there a standard size...for the waste outlet? skip Waste Systems, Tanks & Totes 7 04-18-2004 09:05 AM
Twin bed standard sheet? TomW General Interior Topics 5 03-09-2004 02:00 PM
Standard vs. option? silverback 1999 - 2004 Bambi 7 07-19-2003 02:00 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
