Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Prev Previous Post   Next Post Next
Old 10-16-2009, 04:11 PM   #1
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
Can you Help with my Furnace Problem
Long story short.
Used Furnace NT30 with spark ignition.
After install, the furnace ran through two complete cycles, fan start, heat up, cool down, fan off. On the third try it would not produce a flame. I am 100% sure the sail switch works, the ignitor produces a spark, I can smell gas outside at the exhaust port, I can also hear gas leave the LP tanks while the furnace is trying to start. Is there a chance the spark is not enough or that I am not getting enough gas into the combustion chamber to produce a flame? I see a couple of on-line stores do not let you return a gas valve and at $90.00 I am hesitant to get one and that not be the problem.
Any thoughts?
Thanks - Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Help me with my furnace problem PLEASE macofpei Furnaces, Heaters, Fireplaces & Air Conditioning 22 09-22-2009 11:24 AM
furnace problem nwclassic Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-12-2007 12:15 AM
Furnace problem ddsouth Furnaces, Heaters, Fireplaces & Air Conditioning 11 01-12-2006 06:19 PM
Furnace problem bbrackman Furnaces, Heaters, Fireplaces & Air Conditioning 22 12-27-2004 09:01 AM
Furnace problem Paul Daugherty Airstream Motorhome Forums 20 02-19-2003 04:31 PM
