The Coleman replacement motor is way over two hundred dollars.
I found a Fasco replacement for $126.00 which is made in Mexico
ORV replacement measurements are Shaft .5 diameter X 3.5" X 7 1/8
3.5 is the short shaft and 7 1/8 is the long shaft.
The coleman measurement is shaft .5 X 3.5" x 7 3/8"
The difference between both is the long shaft of 7 1/8" vs 7 3/8"
Has anybody replaced a blower motor. Both look exactly the same. Brackets on motor are the same. You input is welcomed
http://www.emotorpro.com/colemanoem1...h-orv4539.aspx
Link of motor
