07-14-2017, 01:24 PM
#41
Vintage Kin
Fort Worth
Hi
Maybe this is obvious, if so, I apologize:
If running a dehumidifier, turn it off at mid day. It's dumping heat into the space you are trying to cool. Flip it back on at dinner time. Unless you are dashing in and out of the door a lot, the humidity isn't going to climb massively in four to six hours.
It'll depend on locale. Good point.
07-15-2017, 05:34 AM
#42
2014 27' FB International
Clearwater
Replacement Air Conditioner
Originally Posted by ChuckFeldt
I just went through this with my 2014 27FB. Using both a probe type and infrared thermometers, I got 10-12 degree air in to air out differentials. Per the dealer rep this was bad. They are installing a new a/c now at Tampa RV using my extended warranty. Also a battery disconnect relay. The batteries were on me.��
The trailer is home with the new air conditioner.
Temperature differentials in the 28-31 degree range.
Also the compressor is much quieter. We never had the unit blow this cold, I measured 38 def F return air temps at 92 deg late yesterday. I have found the infrared thermometer to be a must have tool.
07-15-2017, 06:10 AM
#43
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
What brand, size and type AC did you install?
07-17-2017, 04:32 AM
#44
Clearwater
AC Replacement
Ext Warranty Replaced the original Dometic unit. Model # I assume the same.
07-19-2017, 08:29 AM
#45
2004 30' Classic Slideout
Fenton
, Missouri
Air conditioner not powerful enough or what?
Our first trip with our then new 2001 27' Safari was in a full sun site on a 104 degree weekend. The Safari came with the then standard 13.5k Penguin. Camped next to me was my former 30' Sob white trailer that had a 13.5k Duo-Therm Brisk air. That owner was on his first trip also with the trailer. As the day went on we got to about 86 F inside. It really was uncomfortable. The white SOB was about 78 inside.
I took the trailer back to the dealership and he said that everything was within specs. The problem was that aluminum does not reflect heat like a white trailer does, and that my Safari was a giant heat sink. I took the trailer to JC and they also pronounced all was well. They did verify that there was a proper baffle in place where the refrigerator compartment contacts the ceiling (a cause of heat intrusion). They did realign my door also.
I decided to add a full length street side Zip Dee awning. This attached to a midline hook when the awning was extended. I never had a complaint about heat again after I had that awning put on. Hence I learned the shiny isn't reflective and when I had my Classic built, ordered the then optional 15k Penguin. If you travel in hot climes, full sun sites, you need awnings and plenty of A/C
capacity.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-19-2017, 08:53 AM
#46
Traveler
2017 25' International
Staunton
, Virginia
Well it's been 100 degrees & 60% humidity here in Kansas and my single a/c is freezing me out I actually have to turn it down it gets so cold. I set it to 76 last night and still woke up freezin!
07-19-2017, 10:29 AM
#47
Fenton
, Missouri
I think the key is the amount of sun exposure you are getting. In my case the heat gain on all that exposed aluminum, with the insulation provided was simply greater than what the 13.5k Penguin could maintain. The output of the A/C unit maintained the proper threshold from the air intake, but as it got hotter outside, the inside temps slowly crept up.
In calling Jackson Center, I asked them what was the design level of performance that I could expect between indoor temps and outdoor temps on my Safari. I was told at that time that there was no standard that they followed. The 13.5k unit was the largest A/C unit available at the time, and if that wasn't sufficient for the weather I camped in, in would need to add a second unit. As long as we were getting that 20 degree drop across the coils, the unit was operating within its specs.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-19-2017, 11:40 AM
#48
Traveler
Staunton
, Virginia
Well I do use the awnings and my roof is white. And the ducted ac is very efficient I find.
Seems 78 is a good setting for me. Lower than that gets too cold.
07-20-2017, 08:26 AM
#49
jkwoodrow
1987 34.5' Airstream 345
Springfield
, Ohio
100+ temperatures in the sun are tough to overcome. Maximizing the efficiency of your AC as discussed previously is the first line of attack.
Another thing that will help is to seal off as best you can one end of the trailer untill after the sun goes down. Open a closet door and seal up with pillows and blankets. It's a compromise but everything is in one way or another.
