Old 05-15-2012, 11:23 AM   #1
1972 31' Sovereign
robstown , Texas
Question A/C in a Land Yacht Sovereign
my airstream has an a/c with a thermostat on the wall to turn on and off
and regulate temp and all that. it does not have a panel on the a/c.
the outside cover is gone and i dont see any type of name on the inside of trailer. there is a vent in the bathroom floor but i dont see any vents or anything anywhere else. I may need to replace the a/c unit. if my a/c guy cant fix it.
what do i do ? do i have to get on top of trailer to see what the brand name is ? and can i replace with a non-ducted a/c if i need to ?
help me please
silvergirl53 is offline   Reply With Quote
Old 05-15-2012, 01:24 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is the original it is probably an Armstrong. Do you know if it works?
You can get a new shroud for the outside and may be able to get an inside cover from an RV salvage yard.
There are many who say these units are better than the new ones and can be repaired. Most RV repair shops won't do anything other than replace it. But you may find an air conditioning shop (residential or commercial) that is willing to repair it.
Old 05-15-2012, 01:26 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post some pics of the inside? You may have to remove a filter or something to locate the nameplate, but it should be on the inside.
Old 05-15-2012, 02:14 PM   #4
1972 31' Sovereign
robstown , Texas
thanks, i think it is original to airstream, i need to check for a label inside.
thank you guys so much.
Old 05-15-2012, 02:17 PM   #5
1972 31' Sovereign
robstown , Texas
there is a cover for it on the inside, all i will need is the outside cover.
keep your fingers crossed it is an armstrong.
thanks you guys. i so appreciate this.
Old 05-15-2012, 02:26 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Inland RV caries fiberglass replacement AC covers. Scroll down the page and click on the thumbnail photo to enlarge the image. They sort of scrunch (that's a technical term ) their photos into a square format so all the thumbnails are the same size. they (the thumbnails) look a little strange, but the larger photos look right.
If you give them a call, they can advise you in identifying what you have.
Vaughan
Old 05-17-2012, 07:41 AM   #7
1972 31' Sovereign
robstown , Texas
Smile
thank you so much
sovereign
