Old 04-10-2015, 05:16 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
2001 11.5KBTU Immediate Cycling
Our 2001 11.5KBTU A/C does a great job of cooling. Everything about its operation is normal except the compressor will occasionally shut off (at a seemingly normal time) and within seconds it tries to restart. It won't of course, so it overloads the circuit such that the fan speed drops. It will try this for two or three cycles and then start up normally. It may then run normally for an hour or so, cycling off and after a while back on, before it does the short cycle again.
Any thoughts about what this could be?
Al
Old 05-20-2015, 10:28 PM   #2
Thermostat?
Bump.
I'm thinking it is the thermostat. If it is a bimetallic coil, maybe as it gets close to releasing it makes an intermittent connection. Is the thermostat (a part of the unit itself) a replaceable part?
Al
Your one immediate upgrade / replace / correct on a new delivery IanPoulin Buyer Guidelines 31 01-26-2015 08:09 PM
Immediate need for an inspector in Vienna, Va! Liberator Dollars & Cents 0 06-26-2013 05:01 PM
Need immediate help.. Univolt mercury7 General Interior Topics 4 06-08-2013 05:48 PM
Water Heater Cycling? BigAl Water Heaters, Filters & Pumps 0 07-06-2004 08:48 PM
