Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 05-09-2011, 08:30 PM   #1
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
Refurbishing Stainless Stovetop
We were able to use 0000 steel wool to bring the cover back to almost new, but the sides and inside look less forgiving. Still new to this, but considered powder coating the insides black or "stainless"... Any suggestions? 
Sammie, Krystal, Lucas, Spencer & Jake!
stowaways is offline   Reply With Quote
Old 05-09-2011, 08:37 PM   #2
1978 Argosy 27
Lacey , Washington
Images: 8
nope, except painting it white.
jjustice is offline   Reply With Quote
Old 05-09-2011, 08:46 PM   #3
1972 25' Tradewind
McHenry County , Illinois
Head over to your local auto parts store and look for brake caliper paint. They claim its good to 900 degrees F. I saw some in silver and was going to do the underside of the stove cover after I got it cleaned up. Might work if your looking for a quick fix.
Thinking off the top of my head again,
Tom
Tom Nugler is offline   Reply With Quote
Old 05-09-2011, 08:50 PM   #4
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
I like the top of your head Tom! Thanks for the suggestion.
Old 05-09-2011, 09:29 PM   #5
reinergirl's Avatar
Hollis , New Hampshire
Now about something like this? POR-20 ALUMINUM-POR-15 Inc.
reinergirl is offline   Reply With Quote
Old 05-09-2011, 11:33 PM   #6
Globie64's Avatar
1964 19' Globetrotter
South Kingstown , Rhode Island
Images: 18
I just used some Por15 metallic paint, and I think you will want to spray it- maybe thats obvious, but I'm kind of low tech. The metallic stuff in my paint came out of suspension easily and didn't go on evenly.
Can we see a picture of the before range top? I need to do the same to mine. Thanks!
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-10-2011, 06:11 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you choose not to powder coat there is this option also:
Thomas’ Liquid Stainless Steel - EShowroom
Old 05-10-2011, 07:06 AM   #8
funkill's Avatar
Tucson , AZ
Images: 27
If you go with the powder coat, you might steer away from the *chrome* color. That's what I chose and when I picked it up, it was FREE. Seems that the owner (who was out of the shop for a few day) would never have suggested the chrome because of the surface imperfections on my cover --- causing the pigments to pool. It doesn’t look that bad, but it isn’t great either. Good luck - how about a pic of the top of your cover too so we can see how your polishing results!
Laura
funkill is offline   Reply With Quote
Old 05-10-2011, 08:33 AM   #9
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
I built a walk in powdercoat oven and used flat black stove paint from lowes. It has lasted forever. If you are going to coat it go with "jet hot" ceramic silver most other powders will fail that close to a flame
Darkspeed is offline   Reply With Quote
Old 05-10-2011, 08:50 PM   #10
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
Laura, I'll snap one this weekend! Frame stiffeners should be done along with the floor on our '69... I'll post some photos of that too. Can't wait to see it...
Refurbishing the Auxiliary Heater Keyair Classic Motorhomes 42 12-05-2017 01:45 PM
Replace stove with stovetop and microwave convection oven dorisbranch Stoves, Ovens & Microwaves 15 10-21-2011 10:07 AM
Solid 31' AirStream FULL STAINLESS STEEL EXT! ORIGINAL! eBay Watch Airstreams on eBay 0 04-10-2011 06:50 PM
silicone caulking for round stainless steel sink toastie Sinks, Showers & Toilets 6 04-07-2011 06:28 PM
Stainless steel screws instead of rivets? Lothlorian Ribs, Skins & Rivets 33 03-22-2011 11:22 PM
