'72 Argosy, what kind of range & where to get parts
I have a 1972 Argosy 20 and getting it into shape for use is coming along good. Some of you may remember, it is the one I posted photos showing a camo paint job ( I have begun prep for new paint ) and I had asked about towing. The handle on the range is broken and I would like to find a replacement. The mfg. tag on the front is missing so I don't know what make it is. It measures 21 5/16 wide so I'm kind of thinking that it may be a 22" Magic Chef.
If anyone could point me in the right direction or maybe even indicate what brand it is, I would appreciate it.
I've got a '77 Sovereign with a 22" 4-burner Magic Chef. One of the burner connections needs repair, but the other three are fine as is the oven with glass window.
I want to replace my unit with either another Magic Chef or an Amana. I've only been able to find 3 burner units, however.
Once I find the new range, I'll sell you mine if you're interested.
Hope this helps out,
Art
__________________ Art, and "Mighty" Velcro Placitas, New Mexico
'77 Sovereign, Reese hitch, Prodigy controller, Kyocera Solar Panels, Honda EU2000i Companion
'99 Suburban, 383ci stroker, ICOM 7000, High Sierra 1800pro, W0ABX, 73's to all you Airstream Hams!
Correction... You can have mine cheap -- make that FREE. It's a Magic Chef, 4-burner, with the window in the oven door. Just removed it for the new stuff we're putting in. It will fit a cutout with the dimensions 20 5/8"Wide, 22" High, and 19" Deep. It has the stainless steel cover and black trim...
Your's for the taking, brother.
Art
Reason: typos...
John
It is indeed a Magic Chef, we had the identical range in our Argosy 20. If no one seeing your post here has a surplus handle, you can place a want ad in our classifieds, it's free and the ad runs for 90 days or so (maybe longer if I get too busy to delete the old ads). I installed a stove cover to give us a little more counter space in our Argosy, counter space beuing almost nonexistent.
I'm sorry it took me so long to reply to your kind offer. My stove is actually working very well and all I need is the handle. The stainless cover would be great too but I'm sure you wouldn't want to split up the assembly. Today I went to an RV parts and salvage store here in East Tennessee. It's called Hickory Corner and the man there has two RVs that he is taking apart for salvage that have Magic Chef ranges with handles that match mine. He told me that he was going to check to see if the stoves work on Monday and if they don't, I can have a handle.
