So I solved my bathroom vent fan question from earlier this week, and I'm on to a new problem!
My Argosy 24 came with one of the very small refrigerators, and I knew from the get go that I wanted to replace it with a 'standard' RV size model. The sizing isn't an issue, and I'm going to rebuild a cabinet around it, but my question is about ventilation.
I've already removed the old fridge and the small cabinet above it. The small fridge had a wall scoop behind it leading out a vent in the ceiling, as well as a hole in the floor covered in wire (was that standard?).
Does the newer, larger refrigerator need to be off of the floor a certain amount? Does it need to vent in a different place or can I cut the scoop back until it's above the unit and leave it be? Are there going to be other issues I'm not thinking about?
I haven't found a fridge yet, but I've found a few possibilities… one of them being a newer (but still used) Norcold N821LT.
Any advice for a newbie before I get myself into something big here?
