The aluminum panel covering our Dometic fridge keeps slipping down into its bottom channel, exposing the rought top edge of the panel. Anyone have this problem? And if so, what was your solution?
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2018 Ford F-350 5.4L SuperCrew 4x4
The insert panel is designed to be 1/8" thick, the aluminum panel may be too thin, a bit of double face tape on the back may keep it from slipping.
Greg
