If your refrig works on gas but not electric, suspect the switch. I had that go out on me (Dometic 2501). The switch needs to make several contacts in order to work.
If you can borrow an amprobe you can check the amount of current the heater is drawing. One of those voltage sensing probes will tell you if the electric got to the heater without even having to get in there to touch it. Lots of excuses to buy men's toys.
Thanks for the replies. The cord insulation was just deteriorated and I was afraid to trust it, and so replaced it.
Plugged it in to an external outlet to eliminate any concern about internal supply.
The switch going bad did not occur to me, but seems the most likely - I'll check that as thoroughly as I can when we get back to it.
