Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-24-2009, 04:09 PM   #1
Elf1's Avatar
1990 34' Limited
Proud to be , an American
Fixed Pilot- Fridge wont cool - PLS HELP!!
Hello All-
I had a thread going on the pilot light not working-
Fixed that issue-
This is a 73- 23'-
The fridge works well on electric- Fixed the pilot-
The pilot ran ALL night- never moved a digit on the thermometer!
ANY thoughts would be GREATLY appreciated - boondocking in AZ- with no fridge leaves me to Kraft mac and cheese w/ powdered milk....GRRRR!
Many thanks-
Elf1 is offline   Reply With Quote
Old 06-24-2009, 06:51 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Since it works on AC, you know the refrigeration cycle is OK. When turned to operate on "GAS" the main burner must come on to cool the unit. The pilot is just there to light the burner, but will not cool the unit by itself-the main burner must come on. You may have a bad thermocouple.
Excella CM is offline   Reply With Quote
Old 06-26-2009, 09:44 AM   #3
Elf1's Avatar
1990 34' Limited
Thanks for the update- Iam off to get a thermocouple at the local RV-
150 miles away - one way-
I will bring the old one....but can you tell me if there is a size or styly I should be looking at/ Are they rated for temperature?
Many Thanks!
Old 06-26-2009, 09:52 AM   #4
Many Thanks!
I don't think you have a thermocouple problem.
Since you have an older Argosy, the burner and it's oriface gets dirty.
You must remove both of those, clean them, and then reinstall the parts.
If that fixes the problem, you owe me coffee.
Also, you will need to clean the reefer flue, to remove the rust and dirt.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-26-2009, 10:01 AM   #5
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
I'm with Andy on this one... if the pilot burned all night, then the thermocouple is good. You've probably got a spider web in the burner tube, or a dirty orifice; although frequently either of those problems will cause a yellow, really sooty flame. I have seen spider webs that completely occlude the burner tube on water heaters tho...
I'd suggest before you make that long journey that you clean the burner well and see what happens. If that doesn't do it, you may have a stuck gas valve... the thing that the thermocouple holds open.
Roger
85MH325 is offline   Reply With Quote
Old 06-26-2009, 01:59 PM   #6
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I went through the same issue with the fridge in my '77' tried everything, replaced the propane regulator on the tanks for another reason and the fridge works just fine now. All of the other propane appliances worked fine before but apparently the fridge was not seeing the correct gas pressure.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 06-26-2009, 10:30 PM   #7
Elf1's Avatar
1990 34' Limited
Royce-
Thanks for the input-
The regulator is new ; as of one month ago-
I am following up with the suggested cleaning that Andy suggested-
All the best for the kind words of advice though-
PLS HELP!!-73 Pilot light won't ignite gas refrig Elf1 Refrigerators 13 06-24-2009 12:22 AM
Fridge pilot light blows out gowyn 2005 - 2010 Safari 3 08-20-2007 12:56 AM
The pilot lights on my fridge but that's it. solsticeelmo Refrigerators 4 07-27-2007 08:10 AM
Dometic fridge not so cool kenajen Refrigerators 15 03-30-2006 05:05 AM
Fridge pilot blowing out TomW Refrigerators 5 10-16-2005 12:20 PM
