Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 07-07-2003, 06:23 PM   #1
Profile:  1983 31' Excella
Bemidji , Minnesota
Send a message via Yahoo to nightowlhooter1
dometic fridge problem
Domestic fridge problem.
Does anyone know what could be wrong with a fridge when the upper freezer compartment works but the lower fridge compartment does not cool? I had it on electric not LPgas at the time.
I am open to any suggestions.
Thank you.
Linda
nightowlhooter1 is offline   Reply With Quote
Old 07-07-2003, 08:32 PM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Airstream Registry
Dometic Fridge Problem
Greetings Linda!
Welcome to the Forums!
You may not have a problem. How long was the refrigerator in operation when you noted the temperature? Especially if you have a Vintage coach with a vintage Dometic refrigerator it will take several hous for the refrigerator to cool noticeably - - the freezer will be the first to actually feel cold. For instance, in my '78 Argosy Minuet it takes about two to four hours for the freezer to begin to feel cold while it might take 12 to 36 hours for the refrigerator to reach its normal operating temperature. In my Overlander which has a two year old Dometic 3-Way refrigerator, these times are much faster - - almost 50% faster.
Another issue that can cause erratic cooling is whether the refrigerator is level - - in other words has the coach been leveled. Again, the older the coach/refrigerator the more critical the leveling becomes. My Argosy is far more sensitive to the degree to which the coach has been leveled than is the Overlander with its newer refrigerator.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 07-08-2003, 06:16 AM   #3
jim8860's Avatar
Profile:
Send a message via AIM to jim8860
The upper freezer compartment works but the lower fridge compartment does not cool
Make sure that the fridge is level.I have also found that if you "stuff " the fidge part with a lots of you favorite food it tends to make the fidge not to work to well . Also If the freezer part get loaded with ice that seems like it makes the fidge part not to cold. Have you cleaned exhaust stack?. What I do some times is to pack a bunch of "blue ices" on door.One last thing how old is it I have seen the older the fidge the more they don't like to be off level.Good luck
jim8860 is offline   Reply With Quote
Old 07-13-2003, 01:43 PM   #4
GoldFever's Avatar
Profile:  1992 25' Excella
Hemet , California
Make sure the door to the fridge is closed tightly all around...we discovered that a pitcher on the door shelf held the bottom portion of the door open even though the top was latched tightly.
Also, make sure the dial is set toward maximum enough to allow the fridge to make the lower part cool enough. We use a fridge thermometer to check how cool it is in there.
Also, if you have teens (we have two) who use the fridge lots to get food/drinks all day, opening and closing the door a bunch can really raise the temp especially on hot days.
Hope this helps
Gary & Susan Norgan
92 Excella 25
(The Silver Twinkie)
Hemet, CA
I retired June 2009, my wife June 2010
"The key to flexibility is indecision"
GoldFever is offline   Reply With Quote
Old 07-13-2003, 01:45 PM   #5
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Airstream Registry
I had the same problem this weekend. After being leveled and lit for 24 hrs our fridge was barely down to 50, which was quite a bit colder than the 90 it was outside, but not as cold as I would like for the food I had in it. When I lit it at home the day before we left and let it run all night empty it got colder than it needed to.
Do these little LP fridges tend to struggle in the heat or should it have cooled off better than that? I guess we'll take an ice cooler to our next camp out just to be safe. I'm starting to see why some people travel with their fridge lit if it takes more than a day for it to cool down to temp with food in it.
Stephanie
Old 07-13-2003, 01:58 PM   #6
montanaandy's Avatar
Profile:
Dometic Fridge Problems
Add me to the list of those having problems with their Dometic (RM100) fridge. I just had the fridge serviced this week (cleaned, checked to make certain that it is operational). The service guy said that it was pretty dirty but that things looked good. Fired it up using LP yesterday - freezer got to 20' very quickly but the lower ffridge portion did not reach the non-spoilage range (30ish') until the sun went down. Out of fairness, it was close to 100' yesterday so I can't complain about the time it took to cool down. Now here is the kicker - today I am attempting to cool the fridge down using elec. which I understood to be quicker. The freezer compartment is down to around 30' (this after about 5-6 hours) but the lower fridge portion has not cooled at all (at 70'). Why would this happen and what might be causing it? The fridge is basically level. Would this point to a thermocoupler problem? Any assistance apppreciated on . Montanaandy
montanaandy is offline   Reply With Quote
Old 07-13-2003, 03:18 PM   #7
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
My experince with our new RM2510, that it does in fact depend on the outside temp.
When it was hot on our last trip 100+ outside, we had to have the fridge on the max setting. We were using gas because I thought it was not working on AC. But it was just because the outside temp was so high. Also, I think the inside of the trailer temp affects the fridge temp too.
When we camped in the mountains last year I found a mid setting ok since the daily high was in the 80's. However, that same setting turned the orange juice into slushies and froze the lettuce at night when the outside temp dropped to the 40's.
Just my experience. I'd say if you can shade the outside of your trailer where the fridge is the better you be.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-13-2003, 05:16 PM   #8
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Re: Dometic Fridge Problems
[i] Now here is the kicker - today I am attempting to cool the fridge down using elec. which I understood to be quicker. The freezer compartment is down to around 30' (this after about 5-6 hours) but the lower fridge portion has not cooled at all (at 70'). Why would this happen and what might be causing it? The fridge is basically level. Would this point to a thermocoupler problem? Any assistance apppreciated on . Montanaandy [/B]
Electric is not quicker. The BTU input of the electric element is a little less than the BTU of the LPG burner. Gas, given a clean burner, should cool it down more quickly.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 07-14-2003, 08:08 AM   #9
beachmpk's Avatar
Profile:  West Hartford
Images: 8
Send a message via AIM to beachmpk Send a message via Yahoo to beachmpk
Smile
We had a similar problem with our fridge. It was always level but as we are camping in the summer it was frequently above 90 degrees. We were told to leave the outside door off of the refrigerator compartment and to adjust the main trailer door so that it was not in its fully opened position. These both improved performance but it was not adequate on those really hot days.
Next approach.....and these worked like magic!!!! We installed a dc powered fan to cool the coils. There was an AC powered fan set up to blow on the coils (is this standard equipment???? I don't know. It did not look like it.) that we detached and replaced with the most powerful CPU cooling fan that Radio Shack sells. (When buying look at how much air it moves and make sure that it runs off of 12V if you wiring to battery) We wired it directly to the battery with wire also purchased from Radio Shack. Total solution cost - less that $30.....and we thought we were going to have to buy a new fridge!
beachmpk is offline   Reply With Quote
Old 07-14-2003, 09:03 AM   #10
Profile:
Update - the Dometic finally cooled down after being left on overnight (it was -`10' in the freezer and 10' in the fridge). So I now know that the fridge is operational (at least when the weather is cooperating
beachmpk - I will look into the CPU fan; sounds like a great idea since the fridge will continue to struggle in higher temperatures.
Misc - I notice that when I close the freezer portion I hear a "woosh" sound (similar to what I hear when I close our deep freezer in the home) which to me indicates that the cooling process is in motion. I do not hear this sound when I close the lower fridge portion. Is this normal or does this point to a weak seal on the fridge?
Montanaandy
Old 07-14-2003, 09:47 AM   #11
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Patience, patience..
It took me a while to get used to the performance ( or lack thereof) of the older Dometic refrigerator in our Tradewind.
Please remember that this does not work as efficiently as your home refrigerator.
Here is what we have done to optimize the refrigerator function:
Do not leave the door open for a long time.
Make sure the vents are completely clean of leaves etc. Especially the roof vent, if so equipped.
Make sure the burner tube is clean, and that the electric heating element is in good working order.
Give the refrigerator time to cool down. Ours takes 6-8 hours to be inthe safety range and stay there.
Use a circulation fan inside the fridge.
Add circulation fan(s) to the venting system to increase air circulation around the cooling fins and tubes. Any increase of airflow helps to remove heat from the fridge. That's what it's doing, not creating cold, but removing heat until it's cold.
Uwe
www.area63productions.com
Old 07-14-2003, 02:23 PM   #12
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Montanaandy,
The woosh noise you hear is the rapid cooling of the warm air that was trapped in the freezer shrinking and sucking the door closed. This is a good thing because it means your door seals are good.
Unless you get the refer portion down to 30 degrees or so you will not hear the woosh because the temp differental is not wide enough.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-14-2003, 07:05 PM   #13
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Dad took his SOB to a repair shop to get the cooling unit serviced. There have been no promises that they can fix it, but they did say they have saved many by refurbing the cooling units.
I'll keep you posted on the repair as it unfolds. It is rumored to cost about $250-$300 to fix if they can fix it.
Eric
Old 07-18-2003, 06:48 AM   #14
Profile:
Refr. Cooling
I did as one other reader did. Install an aux. cooling fan behind the box to move air over the coils. The only thing different I did was use a 110V fan I bought at an appliance parts store for $15. I fabricated a bracket and secured it to the inner wall behind the box. I plugged it into the elec. box that was already located behind the refrig. I also use a battery operated fan inside the door and it improved refrig ops alot. Every little bit helps. I used a 4" fan as the area behind the box is very tight. I used self tapping screws with a 1/4" air ratchet to secure bracket to wall.
davespann is offline   Reply With Quote
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
removing Dometic Refrigerator smily Refrigerators 14 10-29-2007 04:01 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
