03-30-2005, 01:55 PM
#21
Just a member
1978 28' Argosy 28
Lutz
Originally Posted by TomW
My personal fear is that someone (and it will probably be my five year old) will pull the breakaway brake line, and either run my battery down or smoke my brakes, or both. To that end, I'm thinking about putting some sort of buzzer on the system to let me know.
Tom,
If I may make a recommendation. Get a backup alarm and wire it to the output side of the breakaway. If the pin is pulled it would set off the alarm. The only question I would have is if the voltage to the brakes when they are working as normal back feeds into the wire that is fed by the breakaway switch.
Just a random thought....
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
03-30-2005, 02:26 PM
#22
Originally Posted by eljay
Is it paranoia if they really are out to get you?
Just becasue you're paranoid, doesn't mean that they aren't out to get you...
I am not paranoid.
The other voices in my head are the paranoid ones!
03-30-2005, 02:50 PM
#23
1967 26' Overlander
Huntsville
, Alabama
Originally Posted by thenewkid64
...The only question I would have is if the voltage to the brakes when they are working as normal back feeds into the wire that is fed by the breakaway switch...
Yeah, that's the part I'm struggling with. It appears that I will need a black box of electronic parts that will sound the alarm only if the juice comes from the battery wire, and NOT the brake wire.
Now that I think about it, I'm surprised I haven't seen such a device for sale. Maybe I will make one; I could list it on AirstreamBrakeLanyardPulledAlarm.com. I hope Mr. Champ doesn't catch wind of it.
Tom
03-30-2005, 03:27 PM
#24
Massachusetts
Originally Posted by Pahaska
...I keep a padlock through the release lever on my hitch at all times...
Keeping the release lever locked while in transit seems to me to be quite dangerous -- I wouldn't want to be scrambling for a key in the event of an emergency where I would need to quickly release the hitch.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
03-30-2005, 04:03 PM
#25
1967 26' Overlander
Huntsville
, Alabama
Originally Posted by yukionna
...I wouldn't want to be scrambling for a key in the event of an emergency where I would need to quickly release the hitch.
Actually, my plan, in the event of an emergency, is to pull the pin holding the drawbar in the receiver, disconnect the safety chains, and hit the gas pedal. My Overlander will be left with the release lever still locked to the drawbar.
Granted it is tough on the trailer jack, but at this point I would be trying to save the tow vehicle.
Tom
03-30-2005, 04:09 PM
#26
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
I use a lock in the lever. You need to have a pin in there anyway to prevent it from opening while your driving down a bumpy road. (so you don't watch it pass you!) My plan is the same as TomW
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
03-30-2005, 04:18 PM
#27
Retired.
, At Large
Originally Posted by Theo
Nice world we live in, isn't it. Makes me wonder if the 27 years I put in, for the military, was wasted time.
It is a cumulative thing. many individuals together can make a big difference.
03-30-2005, 05:06 PM
#28
Battle Ground
I haven't had any problems traveling out here in the northwest. No one has bothered our rig. But I will keep an eye out. Thanks,
Chuck
WBCCI#7854
03-30-2005, 06:05 PM
#29
Remember, Safety Third
Catfish Corners
, Georgia
Originally Posted by balrgn
NEVER wonder that! Your efforts make our world livable, can't imagine where would wouuld be if not for the sacrifice so few have made!
Hear, Here! Thank you for your service to our country, Theo.
03-30-2005, 09:34 PM
#30
2004 30' Classic Slideout
Fenton
, Missouri
Jcanavera made some excellent posts on these topics in a variety of threads a while back. I found what he & others had to say enlightening. I have not seen him online of late, so I will summarize in case he does not see this thread to comment.
Tom
Tom,
I'm still around but don't have much time to devote since I'm busy getting the dome and convention center ready for the Final Four tournament.
Yes I did talk about this topic some time ago. There had been reports from some folks who stopped at resturants who had receiver hitch pins pulled while they were inside eating.
We always stay with the trailer when traveling and don't go to eat inside at resturants when towing. Our biggest reason is due to the fact that we travel with 2 dogs.
In many cases though we will overnight and will not unhitch. I always recheck everything prior to departure just in case something happens overnight while we sleep.
Folks who do this type of sabotage are pretty sick. If you are one who stops at resturants during travel time, you might consider carrying an extra hitch pin with you as a backup. Even if you catch a theft prior to departing the parking lot, it still would require you coming up with a temporary pin while you attempt to get a replacement.
Better to keep a backup. They aren't expensive.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-30-2005, 09:40 PM
#31
Aluminut
2004 25' Safari
I bought a Master Lock hitch pin. I love it. It not only locks the hitch in, but also any hitch plugs (Airstream has a real fancy $50 one that dubs as a step). At any rate, it can't be removed or modified without a key or a cutting torch.
03-30-2005, 10:09 PM
#32
Putnam
, Connecticut
I like Tom's plan but it would break my heart to dump her. Don't travel with propane on, ever. I put cold food in a fridge prechilled the night before. A few frozen items keeps the whoel thing cold for a day of travel. I wonder if they make that snake alarm for trailers. Or better yet get a real good looking rubber rattlesnake and wrap it around the hitch.
