Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 10-19-2015, 08:07 PM   #21
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Campgrounds sound complicated.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-19-2015, 10:32 PM   #22
Proud Owner Vintage SBB
'55 Airlight's Avatar
Santa Monica , California
Images: 105
Originally Posted by FollySteve View Post
Love it !! Ask them, "What, you didn't get full hook ups?!"
"There're a bunch of utility full hook up poles around; just gotta look for 'em..."
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 10-20-2015, 01:42 AM   #23
IanPoulin's Avatar
2021 25' International
Full timer , Virginia
Originally Posted by moosetags View Post
We use a short stringer hose to a "Y". Then we use curly spring hoses from the "Y" to the trailers connections (city water and Sewer Solution). All of our hoses are rated for drinking water. All of our water hose connections are via quick-connects.
Brian
I guess my question is that if your sewer solution backflow preventer fails, and you discover it only later, how do you tell which hose went into that system? This is the unlikely and "unforeseen" circumstance I envisioned when I went with green hoses for flush and sewer solution and kept the white only for fresh water and mister.
2024 Airstream Globetrotter 30RB
2022 Ford F350 Lariat Diesel
WBCCI 4CU 8118
IanPoulin is offline   Reply With Quote
Old 10-20-2015, 09:29 AM   #24
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
WestieHouse - I use two as AStreamNerds suggests. With the Anderson's it's simple and there's no stress on the frame which leads to "door slam" problems.
The Ice Man is offline   Reply With Quote
Old 10-20-2015, 11:29 AM   #25
2019 25' Flying Cloud
Sequim , Washington
Thanks, Ice Man. Makes good sense to use two Andersons.
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 10-20-2015, 01:17 PM   #26
IanPoulin's Avatar
I know I am tangential slightly, but the jury is out on my Anderson levelers so far. I've had a few situations already where on soft ground, the "set" block re-adjusts during the week allowing a 1-2" drop and loss of adjustment. still playing with it though.
WBCCI 4CU 8118
Old 10-20-2015, 07:34 PM   #27
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I've got about 1,700 nights on the Sewer Solution. The back flow preventer has never failed. I'm just not going to worry about that.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-24-2015, 03:15 PM   #28
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Some fantastic ideas. I am getting the hose. My Never Kink always kinks and is a mess.
Re: WiFi/HDTV AIR:
Those that still have the crank Winegard have some options to add WiFi and even a new frequency HDTV antenna to the batwing mount. Crank it up and you have your antenna array ready to go. Turning it is nearly a mute point with the new antenna so I rarely have to mess with it once lifted. Saves time.
Please tell me more, link, etc., on how to update the crank winegard with WiFI and the new HDTV antenna.
Yes, the antenna update "kit" I got from Winegard. It basically uses the crank up system already in place for the batwing but you remove one rod. The kit for those that have a batwing is:
Winegard Rayzar Air - RV HDTV Antenna, RV Antenna
they also have the fully automatic disc model but I do not know how well it performs.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 10-24-2015, 04:16 PM   #29
IanPoulin's Avatar
The disc model doesn't work as well as the crank and rotate aerial
2011 Airstream International Serenity 28' - 30a/taupe
2013 Ford F150 v6-ecoboost with max tow and HD payload packages
WBCCI 4CU 8118
Old 10-25-2015, 06:11 AM   #30
2006 25' Safari
good to know. I CAN testify that the new "paddle" razor works better than the batwing with HD nose as I upgraded and it got more channels. It is bi-directional so there is that much less turning. I have the power signal indicator sensor pro which was very useful with the batwing now, not so much.
Winegard SensarPro TV Signal Strength Meter
Old 10-25-2015, 03:43 PM   #31
ranchometal
2014 23' Flying Cloud
2018 25' Flying Cloud
Mare Island , California
Thanks much for the link.
ranchometal is offline   Reply With Quote
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 08:12 AM
Full hook-ups close to Port Orchard, WA? DianePhx On The Road... 2 07-23-2014 12:07 PM
hook ups for water tank , pump and tie ins batt Fresh Water Systems 3 10-03-2010 07:10 PM
Hook ups? watt1968 Plumbing - Systems & Fixtures 12 05-01-2008 05:53 PM
West Cheap or Free Hook-ups - MT CTHilmo Boondocking 3 04-09-2006 08:45 AM
