12-09-2006, 09:57 PM
#21
Remember, Safety Third
Catfish Corners
, Georgia
OK, so I just spent a couple of hours reading the info over on the Tigerfoam and Sprayfoam websites. I can’t think of any reason not to use this stuff. Probably the biggest selling point is that it already being used in RV’s, Boats, Refrigerated trailers and the like. These newer formulations are much more rigid than the old stuff. It actually helps to dampen vibration, rather than being torn apart by it. You get about an R7 value at 1” application. Not bad. Condensation is not a problem because of its thermal properties. It actually seals out water.
I think I’m gonna use this stuff. Melody Ranch—keep one of those paddles ready for me, just in case.
12-10-2006, 12:35 AM
#22
Silver Mist
Riverhead
, New York
I bought the bubble Foil for about $.25 a sq, the foil has an R value of 14.
Very quick and easy to install.
So your getting half the insulating value R-7 for three or four times the cost.
Your also would be using something that can have other unknown factors when you install it and or in the future.
12-10-2006, 07:15 AM
#23
Old Paint, rolling again.
1973 Argosy 20
Lorain County
, Ohio
Foiled again?
2 questions:
What will the foam weigh overall, and is it possible that it raises the center of gravity of the trailer too much? "The density of TIGER FOAM is 1.75 lbs. per cubic foot." Is that the actual weight? (600bf divided by 12 x 1.75 = 87.5 lbs of insulation?)
Will it be difficult to apply in an even thickness, without too much waste?
One big limitation of the foam is that it must be applied above 75 degrees f. Bubble can be applied in the off season but a summer foam application probably kills a good chunk of ones camping season (putting everything back together and all).
Foam still has many unknows but has double bubble foil even begun to stand the test of time?
Hmmmmm?
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
12-10-2006, 07:23 AM
#24
Originally Posted by Jim & Susan
. . Mark, didn’t you use a flexible conduit on your rebuild? What type and how expensive was it? I’m about 1/3 of the way complete cleaning and inspecting the original wiring in mine and I have to say it is still in excellent shape.
Jim,
The wiring in my '59 was pretty basic, and I wanted to add separate circuits for lots of new stuff, like propane detectors and more lighting. That's the reason I did a complete rewiring.
With the number of dc circuits (up to 20 so far) I think it was easier to run conduit. It keeps the wiring more organized.
I used what is commonly called "Smurf Tube", for its blue color. It's corrugated plastic, very easy to work with, and uses snap together fitting. The tubing is very cheap, a couple of dollars for a 10 ft length. The fittings are more expensive, about 60 cents each. Shop for the fittings, sometimes you can find them for less.
The tubing is about 7/8" diameter. If you feel that cutting a hole in your frame channel is going to compromise the structural integrity, then don't do this. I have no reservations about a few holes.
Here is an illustration.
12-10-2006, 07:31 AM
#25
1994 30' Excella
Milwaukee
, Wisconsin
Weighing all the options we signed the contract to have cellulose blown into our house instead of the foam. I researched it and the foam was far superior but with the cost being three times that of cellulose we will be long dead before we realize any savings. Using it in Chummy is still an appealing option due to the noise reduction factor since we ride inside. I have found that all of my wires are encased in a caulky, gooey stuff now which makes it impossible to pull new wires through the walls. Any new wiring I have done has gone on the surface so that is not a problem.
Chaplain Kent
Forest River Forester 2501TS
12-10-2006, 11:52 AM
#26
Jupiter
I'm fatigued over hearing over-blown R-Values of bubble wrap insulation products - this isn't personal friends, this is big business putting a bug in folks ear that gets repeated far too often.
The Reflectix people hype their product like old fashioned snake-oil salesmen; if one wants the testing procedure and outcomes you must call the company to get a copy - they only transmit the maximum vale in their literature... The Insulation 4 Less company is more forthcoming with true details:
R Values - single layer foil-bubble-foil
Heat flow down: 14.1
Heat flow up: 4.9
Heat flow horizontal: 6.2
(R Values determined in guarded hot box facility according to ASTM C236, to achieve published R-values the air space must be at least 3/4" and be perfectly sealed... (among other things))
The Prodex Foil-Foam-Foil heat down flow resistance is R14.5 but has sound deadening properties which is why I chose it. I paid 32¢ sq/ft for foam core, the same site has foil bubble for 26¢ sq/ft, delivered
What I would like to see is a combination installation, say one-half or three-quarters inch of spray closed cell foam and then the Prodex foil-foam-foil laid on liner panels - or vice-versus, but leaving a small air gap between them. Would certainly improve energy consumption and livability in our vintage Airstreams to have true R-8 to R-10 or better in ceiling and walls...
I would also like to see a structurally sound thermal barrier system to isolate the interior liners off of the frame ribs to keep conductive heat flow to a minimum, something like the mud-sill roll foam that carpenters use to float wood framework off of concrete to stop moisture and heat flow but not as 'live' to handle vibrations from motion. I've used sill-plate foam between 5/8" foil backed drywall and wall studs with good sucess in my 1920 Minnesota farmhouse. Maybe 1/8" cork glued to liners, eh?
Anyhow, thanks for reading this far!
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
12-10-2006, 02:32 PM
#27
Steve
The two components must be above 75, the ambient temp/surface temp can be lower.
12-10-2006, 02:35 PM
#28
Electrical (grey) PVC fittings can be glued on to smurf pipe.
12-10-2006, 03:32 PM
#29
1975 Argosy 26
Covington
, Louisiana
Re: foam insulation
I am specifying the product "Icynene" in new and existing construction - great stuff. The applicators have large investment in equipment and even so the market price is 37 cents per sq. ft. of surface @ 1" thickness. It is more expensive than the fiberglas products and worth it. Using this product has allowed reduction in heating and cooling equip. size by 20 to 25 per cent. I have no affiliation with this product, just consumer experience. It is a mess to apply I recommend haviong an applicator do the job.
12-10-2006, 07:51 PM
#30
Tramp Streamer
1995 28' Excella
Artist
, at Large
Originally Posted by cadmando
Re: foam insulation
Hi Cad,
I was just in Covington!
Parked in the court house parking lot for a few days, and got sunk in the mud along the back of that lot. The nice folks at H&K automotive pulled me out. Nice town
Michael
12-10-2006, 07:54 PM
#31
Catfish Corners
, Georgia
2 questions:
One big limitation of the foam is that it must be applied above 75 degrees f. Bubble can be applied in the off season but a summer foam application probably kills a good chunk of ones camping season (putting everything back together and all).......Steve
Steve, my impression after all that reading last night was the weights you are looking at are for the "wet" or "uncured" product, but I could be wrong about that.
It doesn't seem all that hard to apply, unless you make a mistake. Clean up could be a nightmare.
The 75 to 85 degree application temp is for the foam only. They recommend that you heat the 2 part foam containers with small fan-forced space heater if applying in winter. The temparture of the surface that it is applied to is immaterial. It also cures very quickly, even in cold weather.
12-10-2006, 07:59 PM
#32
Putnam
, Connecticut
Jim,
Nice work. What's that red line diving into the wheel well?
12-10-2006, 08:04 PM
#33
1956 22' Flying Cloud
West Linn
, Oregon
Hey all, I know that this horse has been beaten to near death but... for the cause of science I thought that I would throw out another INSULATION idea for your consideration: Quick curing two-component spray polyurethane foam insulation.
It's the stuff that you've seen used on PBS's This Old House. They spray it into the open stud bays where it sticks and immediatly begins to expand. Usually they spray it on thick enough where it expands beyond the face of the studs and is then cut off flush to the wall surface. In an older home renovation the benefit is that it seals the walls and acts as a moisture "resistant" barrier. I may use it on the house we are about to purchase, a century home with plaster walls and no insulation. The foam can be sprayed (or poured ?) through small holes into the wall cavity where it rises and fills it up providing R-7 per inch of wall thickness.
On an Airstream perhaps spraying 1 inch thick into the open wall and then adding foil would be a good use? It's not cheap but it will provide another layer agains water penetration, provide more soundproofing, it's non-offgassing, and mold doesn't like it
Also could an ideal use be for insulating under the floor?
This is the only DIY distributor I've found so far. Good web site with lots of tech info and FAQs answered.
Tiger Foam Insulation
By the way, the trade name is ICYNENE
Merry Christmas!
Steve
Steve, DONOT USE SPRAY FOAM INSULATION!!!! Im telling you is sounds like a great idea, and does do all the things you say, but the heat thats generated by the reaction of the curing of the foam will warp the sides and the corners of the trailer, I speak from experence!!! and as a result I had to replace all of the side panels, 4 sheets and a lot of time. It was bad enought to have too do it the first time, it took me serveral months because of my work. but to have to do it again was almost too much. I ended up keeping the foam on the roof, end and front panels, and some on the corners, other then that it's all gone.
12-10-2006, 08:05 PM
#34
1973 Argosy 20
Lorain County
, Ohio
Red would be for fire suppression, right?
Very clean looking installation Mark!
Steve
12-10-2006, 08:13 PM
#35
1973 Argosy 20
Lorain County
, Ohio
Originally Posted by Dan Clayton
Steve, DONOT USE SPRAY FOAM INSULATION!!!!...to have to do it again was almost too much.
You replaced the panels twice, why?
It sounds like this temp problem is serious, but perhaps not insurmountable. Different types and formulations of foam probably react differently. Maybe keeping the skin cool would help, or application in thinner coats? Thanks for the heads up! It's great we can explore this fully with such a broad range of experience brought to bear on the question.
Steve
12-10-2006, 08:16 PM
#36
Catfish Corners
, Georgia
Originally Posted by Wabbiteer
I'm fatigued over hearing over-blown R-Values of bubble wrap insulation products - this isn't personal friends, this is big business putting a bug in folks ear that gets repeated far too often…….
I too, am skeptical of some of the Reflectix claims. The material I looked at listed R-values from R-3 to R-14, “depending on application”. What the heck does that mean? I have to admit, I didn’t spend as much time on the Reflectix website as Tigerfoam. I’ll go read more.
Which website? The Prodex website? I think I read about Prodex hear on this site once. Does it only come in 4’ X 8’ sheets? How flexible is it?
Actually, the Tigerfoam people recommend this in some building applications, sorta. They recommend a one inch foam application against the outer walls with a layer of the pink stuff on top of that. I don’t remember all of the details because there really isn’t enough room in my 1.5 inch walls to consider something this (I just kinda skimmed thru that section).
Somebody here on this site did just that very thing. It may have been JC Ferguson, but I could be wrong. Whoever it was, they used a cork barrier along the ribs in a similar manner to what you are suggesting.
12-10-2006, 09:22 PM
#37
Thanks. The red line is a drain line for my new air conditioner.
The coils of black and white wire are coax, and the 120vac wiring is MC lite armored cable.
12-10-2006, 10:25 PM
#38
Corpus Christi
Wabbiteer, for a thermal break between the ribs of the trailer and the inner skin, you could use 2mm EVA foam strips similar to those used for grips on windsurfing booms. Murray's Marine carries it for windsurfing booms but it would be pricey unless you worked a deal with them. The strips could be applied with Superstick double sided tape from Challenge Sailcloth. The adhesive is very aggressive and is unaffected by moisture. A thermal break between the ribs and the interior skin is an excellent idea because aluminum readily transmitts heat and it doesn't take much of a thermal break to make a significant impact on heat migration. Before applying the interior skin, put a strip of eva foam on ribs and any other points where interior skin is attached, then attach skin thru the eva to the rib in the normal way.
EVA foam comes in many densities, but it is often used on kids toys, flipflop shower shoes, and sporting and marine goods.
So Long!
12-10-2006, 10:38 PM
#39
I used quarter inch cork for this purpose - I used spray adhesive to hold it in place on the ribs and then rivetted the skin in place through the cork. I think it works pretty well - before I put in my new skin I could see lines of condensation over the ribs in the morning, after adding the thermal break, the only condensation is on the rivets. Now to make rivets out of cork! I am interested in this discussion - I used the foil bubble but might consider the spray-in for the next project...
Carlos
12-11-2006, 09:03 PM
#40
West Linn
, Oregon
Steve, The best product is the one that has the fastest curing time, and heat will be generated in any of the foams that are put out today. and oddly heat is a important factor in how well it will hold up over time. The foams in a box will not last, and cost 10 times as much as having installed by a foam business. I used a type that is well know in the RV business, can't recall the name, but it can generate heat up to and over 200*. There is no problem when using it on 16 gage metal or very thick fiberglass, but when your talking 0.32 gage metal that's a whole different story. I had to replace the sheet metal on the side walls because it was like a ocean wave. When the foam was first sprayed on I guess there was no issue, but as it cured and the heat generated then the warping started. I would just stay with the old type of insulation, or foil bubble. Sometimes it best just to stick with the old technology.
