11-22-2014, 02:18 PM
1984 31' Airstream310
Ajo
Removing duct tape, help!
Anybody have a clue how to get the spoils off before the coach goes in for repair? Thanks, M
11-22-2014, 03:02 PM
2019 27' Globetrotter
Missouri Valley
, Iowa
I would think mineral spirits or goof off will soften it for easy removal. That's the exterior isn't it?
Dan
11-22-2014, 03:17 PM
Ajo
Dan
Thanks, Dan, yes, it's the stern that was smashed. M
11-22-2014, 03:23 PM
2007 22' International CCD
Corona
Sometimes using fresh duct tape to pull off as much of the old adhesive first works well. Stick it on, rub on firmly, then peel off slowly that may get more of it off, then use solvent as needed. I try to avoid using a lot of solvent because it is messy to get completely clean when the glue dissolves.
11-22-2014, 03:35 PM
Ajo
The tape has been on awhile, will try all your suggestions. Thanks, M
11-22-2014, 03:43 PM
2002 31' Classic
Monroe
, Iowa
Have you tried WD 40? It usually works for me. It won't hurt the paint, either.
11-22-2014, 04:14 PM
2017 25' International
Los Osos
Automotive - Clear Coat Safe GoGone.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
11-22-2014, 05:33 PM
Dazed and Confused
Hillsburgh
, Ontario
All good suggestions.
Where is the coach going into for repair and did you have any luck getting the rear banana wrap replaced?
Good luck
Tony
11-22-2014, 05:50 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Bestine.
Shari
11-22-2014, 06:03 PM
Ajo
Good luck
Tony
We think she'll go to Phoenix, but have no clue at this point. Parts are iffy.
11-22-2014, 06:12 PM
1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
Duct tape
if you are going to have the area repaired why worry about the tape residue? the shop will have to re-apply clear coat anyway.
I use plastic razor blades and then goof-off (available at Lowe's & Home Depot). It will take the clear coat off.
