I use one on my black tank--I do not usually carry any gray water, because I keep the gray dump open and the gray tank empty all the time..don't need to use the gray water to flush the stinky slinky.
It is quite effective at pumping/macerating the contents of the black tank using the built-in water jet. I also have no problem pumping 'stuff' uphill a bit, either. The same jet, rotated, is also very good at flushing the black tank clean--better than the built in flusher my AS has. The water jet also makes it very easy to get the SewerSolution head and hose nice and clean when finished dumping.
It is MUCH easier to handle and store than the stinky slinky. I have a clean, new slinky in the storage tube, it came with the trailer--and never has been used.
I did have to add a short straight clear adapter to easily get the SewerSolution hooked up--my tank dump is recessed fairly far under the trailer, and that straight section makes it easier to hook up without a struggle.
All the bits and pieces store in my bumper storage and are thus separated from the clean stuff like the power cable and shore water hoses--they live in a collapsible crate in the back of the tow vehicle.
