Old 01-21-2019, 11:51 AM   #1
CAV
CAV's Avatar
2004 25' International CCD
Dubuque , Iowa
Question Replacement Roller Shades
Have 2004 International with roller window shades. Fabric is deteriorating. Considering Zarcor replacement roller shades which are standard in newer Airstreams.
Anyone with experience with replacement installation?
Did you select toggle cord or mini grip closure device to secure bottom of shade & why?
Did you remove the previous closure snap in the wall (how big is the hole)?
Any other comments? Thanks!
CAV is offline   Reply With Quote
Old 01-21-2019, 01:37 PM   #2
1955 22' Safari
Laredo , Texas
Like these?
Here are the ones I put in my 55 Flying Cloud. Are those the ones you mean? Pricey, but very nice. I used a hold down fitting at the bottom
Name:	Aft end cap1.jpg
ID:	332113   Click image for larger version
Name:	Center aft end cap.jpg
55AS is offline   Reply With Quote
Old 01-21-2019, 02:46 PM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
I retro fitted our Bambi with them and went with the std. toggle.
The toggle is small though and a bit hard to use with fat fingers like mine.
If you are using them over a fixed window consider the hold tabs for the sides if you want to have the ability to have more positions than up or down all the way. On the operable windows the lower blind bar can be held open with the window operators in a raised part way condition.
Ours had mini blinds so some of your Q's dont apply.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 01-21-2019, 03:56 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I had a 2005 International too, and the window shades in it were standard big box hardware shades. The wood rollers warp due to pressure on the hold down and the fabris has probably gotten sun faded.
You might want to consider the economy route... having shades cut to size at a hardware chain and installing them with the existing hardware. These can also be turned into custom shades by replacing the vinyl shades with a lightweight fabric backed with non-woven interfacing.
If the pricetag for the factory shades doesn't scare you off, any holes that dont mate up with the new shades can be filled with a pop rivet. The shades will need a hold down for towing.
Old 01-21-2019, 04:09 PM   #5
AlinCal's Avatar
1991 25' Excella
The pricing direct from Zarcor is not horrible and the product is first rate,
They also offer free filler plugs for your unused holes.
Will Rogers
Alan
Old 01-22-2019, 12:41 PM   #6
CAV
CAV's Avatar
Dubuque , Iowa
Thanks everyone! appreciate the information. I like the look of the top cylinder that contains the roller; my current one has no "header" and looks unfinished. Will consider replacing fabric only; and minimizing # of new holes. Have been trying to upgrade finishes year by year. The Zarcor folks seem very familiar with Airstream installation. thanks again!
New Flying Cloud OceanAir Roller Shades Question. cabinetmaker 2016 - Current Flying Cloud 7 10-05-2015 11:11 AM
Roller Shades in CCD theSubdude Upholstery, Blinds, Walls & Interior Finishes 18 05-11-2014 02:44 PM
roller shades featherbedder Upholstery, Blinds, Walls & Interior Finishes 3 04-19-2012 09:50 AM
Caravel replacement roller shades??? hayfever 1969-1971 Caravel 5 09-21-2009 06:13 PM
Best way to hold roller shades bgarrison Upholstery, Blinds, Walls & Interior Finishes 8 04-07-2009 05:57 PM
