04-15-2012, 07:59 AM
Milford
, Ohio
Need details on original drapes
My original drapes were removed long ago by a previous owner and I plan to make my own in a similar style. I have a few technical questions that owners with original drapes or expensive replacements can answer.
I have snaps pop riveted to my interior walls near the upper and lower corners of where a curtain panel would be. I assume there is either a snap concealed in the hem of a panel, or a tab with a mating snap sewn on that tucks behind the panel. The purpose of these I assume is to keep the ends of the panels from coming off the tracks and I'd like to know how it is done.
In my living room above the credenza there are two windows side by side. Since the drapes will part in the center of each window, I was wondering if the original design had three panels here, with a larger center one that overlaps the space between the two windows. Seems like it would result in a cleaner look than if done with four panels.
Whenever I do this project I'll post some photos.
Christopher
04-15-2012, 09:57 AM
1977 31' Sovereign
Fresno
Hi Christopher,
I currently making new curtain for my 77 Sovereign. I'd be happy to help you out since I'm in the thick of it.
The curtain have a small 1-2 inch tab at the corners of the curtain with the other male end of the snap. The snaps just anchor the curtain from sliding all the way across the tracks.
Do you have a front couch? There are four panels there and they do part in the middle. The four panels follow the curve of the wall and cover the speakers.
I can take pics if you need and help you with dimensions too. I still have my curtains which were replaced sometime in the 80's by the PO. I am using those as my template and so far it's working out great.
Cheers,
Cara, John & Johnny
Jet, Our silver stow-a-way
1977 31' Sovereign "The Mod Pod"
2006 Ford F-250 Super Duty
04-15-2012, 10:37 AM
1974 Argosy 20
Kooskia
, Idaho
Drape details
Here are three pictures of the totally original drapes in my '71 Caravel.
You can see how the end of the drape is turned inside out so the snap does not show, and the curtain edge is hidden. You can also see the pleat system and the lining used in the drapes of that era.
Hope this helps you out.
04-15-2012, 10:43 AM
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
The side by side windows
Christopher[/QUOTE]
Yes, our side by side windows in the living room are on the streetside. They do indeed have 3 panels. A small panel on each end and a longer panel in the middle that covers from the middle of each window and over the section in between the windows.
If I had to do it over, I would add extra length there as ours seem a bit too short to close up the gap. I have added velcro tabs at the corners to keep them from gapping open at night.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
04-15-2012, 10:54 AM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
In my Excella, the center panel is the smaller on while the larger ones are at either end. This allows the center one to not block the view as much when they are open.
I also have venetian blinds on the side windows in the living area. The center panel is wide enough to block the gaps between the blinds and the wall, while the end blinds close off the gaps at either end of the window pair. Helps with privacy.
Someone asked for the number of pleats in the curtains a while back. Easy to count pleats, not so easy to measure lengths, while they are installed. Anyway, the two end panels have 8 pleats and 10 glides-one on each pleat and one on each end. The center panel had 5 pleats. No snaps on the center panel. Remember, these are for my 1983 34' Excella. Yours may be different, but it still gives you something for comparison.
On edit after loudruff's post: My curtains came with Velcro at the pleats to keep them together. Still kind of works after 29 years.
Vaughan
04-15-2012, 12:03 PM
Milford
, Ohio
Mrs. Mod, yes I do have a couch in the front, right across the front of the trailer, with its back to the window. So you say the curtains for the front which wrap around are in four sections? I would have guessed two longer panels.
Do I understand correctly that the two end panels are smaller, just enough to cover the speakers, while the two center ones would cover the front window?
I would like to see photos of your work, and also know a bit about the shape of the front panels. With the lower track being longer than the upper, I wasn't sure if the drape panels were cut out as rectangular or with an angle at one end, or maybe cut in a slight curve at one end.
idroba, I can see how on the front window the snap would work folded under on the corners, while on side walls tabs off the end would work better.
As for the classic pleats at the top, I was hoping to come up with a simpler design. I am by no means a seamstress, but I have a lot of determination.
Christopher
04-15-2012, 12:24 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Christopher
Actually, it's more complex than that. There are pleats on the bottom, too.
Vaughan
04-15-2012, 12:30 PM
1972 31' Sovereign
Lexington
I have invested (and I do mean invested!) in night shades but I am planning small side curtains (got that fabric cheap) for each window to keep the shades in place (otherwise I'm told they'll gap at the sides when closed). I'm going to use an easier pleat on mine since they won't be functional for the most part, by just folding a pleat over towards the outside of the window every few inches and stitching it down. Vintage Trailer has the best deal on the tracks and hardware for them. You can get larger quantities for cheaper prices than otherwhere. I will be making functional pull across drapes for my side front windows the same way. I'm going to do a valance across the top of each window to hide the shade top piece. Haven't quite worked that out yet.... I'm also going to line my curtains with lining fabric to keep them from fading. We were in some new AS at the dealership a few weeks ago, and the curtains in them were not lined and looked really flimsey. Not like the older ones at all! I would definitely line my curtains!
Kay
04-15-2012, 01:52 PM
1977 31' Sovereign
Fresno
Pleats can be fun and are easier once you see how they are done. Hmmm, maybe I should make a video tutorial.
Cheers,
Cara, John & Johnny
04-15-2012, 07:38 PM
1972 31' Sovereign
Lexington
hey, Mrs. Mod, you could make some money on that tutorial! I'd buy it, and by the number of threads about curtains right now, others would too..
04-15-2012, 08:23 PM
1989 29' Excella
Lorain County
, Ohio
Ditto
That tutorial would be a great hit!!!
Larry and Lou
Air #2695
TAC- OH 2
04-16-2012, 09:14 AM
Milford
, Ohio
I have a question about those top and bottom pleats. If these were regular drapes for a house window with traverse rod, you could sew pleating tape onto the drapes, and then insert the the little prongs which fill out the pleat and have a hook on the back for hanging. Now in an Airstream trailer the curtains attach with these little plastic glides that I believe sew on with a small loop of elastic.
So how are the pleats made on the original drapes and reproduction ones? Sewn painstakingly one at a time?
Christopher
04-16-2012, 10:46 AM
1977 31' Sovereign
Fresno
Christopher
Yes, the pleats are made one at a time, but it's not as slow as you might think. I didn't think I could do it either but once I saw it done, it was really easy. I have only been sewing for about a year. Ok, well, in that year i've been pretty much sewing non-stop. I'm a quilter now.
I'd be glad to make a video or picture tutorial. Right now, I'm waiting for my order of pleat tape to come in the mail. You need pleat tape. Once it arrives, any day now, I can resume making the curtains.
Meanwhile, I'll start writing up the instructions. Give me a few days. I'll post my instructions maybe other sewists can give their input too.
P.s. once my curtains are finished, I'll have my old set which are not in bad condition up for grabs. They can be cleaned and they need new clips sewn on. Or you can have them for templates.
Cheers,
Cara, John & Johnny
04-16-2012, 11:55 AM
Milford
, Ohio
Ah, so you will be using pleater tape. From what I've researched that looks like an easy way to go since it sews on flat. However, once it is on your drapes, as I understand it, you then insert those forked hanger hooks that shape the pleat.
An idea that I had was to use pleater tape, insert the forked hangers but then cut the hanger hook portion of them off. Maybe secure them in place with a hand stitch or two if needed.
I'd have my plastic glides sewed on near each pleat, top and bottom. Are your plans similar?
Christopher
04-16-2012, 12:09 PM
1977 31' Sovereign
Fresno
Christopher
Christopher,
I thought it would make things simpler to eliminate the pleats also, but seriously, it's easy. If you can manage to sew a straight line, you can do it! I think you should leave the pleats. In my opinion, they give the curtains a nice, crisp look. Do not be intimidated by the pleats. I was at first but then I watched a YouTube video about making pleats and I couldn't believe it was that easy.
I know you have a hard task ahead of you since you have nothing to look at as a model. I studied the construction of my old curtains for a good amount of time before I started cutting up fabric.
The top to bottom dimensions have to be perfect or the curtains will be saggy or not long enough.
I searched a couple of sources for elastic clips. I found that Inland RV had the best price. There's not much of a price difference, but you get a few more clips for the same price as the other guys.
One more question for Christopher, do you have a center bath model? I have a center bath, I think there is plus or minus one curtain panel on a rear bath model. In any case, I would think the number of panels is something that wouldn't matter as long as you're satisfied with the coverage.
I'm pretty sure all the panels are a straight rectangle. I'll know when I take that set of curtains down (they're next). I'd go look, but we don't keep our AS parked at home.
Cheers,
Cara, John & Johnny
04-16-2012, 12:20 PM
1977 31' Sovereign
Fresno
Christopher
Yes, I'm using pleat tape. It keeps the edges straight and crisp. The nice thing about pleat tape (which is why I'm sure it was invented) is you can fold it like paper when making your pleats. Then, just sew a straight line through the folded section. Mine do have plastic guide on top and bottom.
I machined sewd my elastics clip on after my curtain were completely constructed. That way, if I ever have to replace a clip, I only have to undo a small bit of stitching to remove the old clip. They are space evenly between each pleat except on the end where the snap goes. Snap holds it in place.
Ok, here's the tricky part. There are two kinds of clips. The t-clip and the g-clip. Both named after the way they are shaped. T-clips are used on the top in some places.....and the bottom in some places.....and G-clips are used on the tops in some places and the bottom in some places with no apparent rhyhym or reason. Did you notice this when you ordered your new clips?
Cheers,
Cara, John & Johnny
04-16-2012, 12:56 PM
Milford
, Ohio
Thanks for the descriptions, they helped quite a lot. The pleat tape I had been thinking of has pockets for the fork-style hangers, but yours sounds better suited for this job. If you could post a photo or two of the backside of a drape's top or bottom edge that would probably be all I'd need for now.
To answer your questions, my trailer is a center bath. However, right now I only plan to make drapes for the living room. I have not ordered any glides yet, though I know about the T and G types and where to get them cheap.
Do you have any advice on curtain width? For example, my curb side window has a track 38" long. Two perfectly flat curtains would be 19" each, though I planned on doubling the width of each to account for the pleats.
As for the height, I know that will be a critical measurement. I was thinking the elastic attachment loops might allow for a bit of slop.
Christopher
04-16-2012, 01:02 PM
Wabash
, Indiana
blickcd,
I have replaced my original drapes with regular curtains and regular rods and no longer have the originals. However, I also have a 79 sovereign and will be happy to help if I can. Ours has the goucho in the front, bath in the middle, and full bed in the back.
04-16-2012, 04:07 PM
Milford
, Ohio
CampUnger, we have the same floor plan, including that rare full sized bed. All of my original drapes were removed by a previous owner, and while I've been putting this off for years I am finally going to install some new ones.
For the living room I want to restore the original look. However, when I do the bedroom I'm not sure if I'll want to bother with that full wraparound style of pleated drapes. Sort of depends on how the living room job goes. In short, I'd like to see some bedroom photos, which I know are tricky to get in that small space. Mainly interested in details of the upper and lower rods, how they attach to the walls and drapes.
Mrs. Mod, can you post a link for the source of the pleating tape you are using? I checked with a local Joann Fabrics and they don't carry what you describe.
Christopher
04-16-2012, 04:27 PM
1977 31' Sovereign
Fresno
Here are some pictures of my old curtain. This curtain is from the window that is right next to the door. It uses 4 T-clips on top and 4 G-clips on the bottom of each panel (total of 8 of each)
Pic#1 This is the type of pleat tape that I used. It feels like an extra thick dryer sheet. It is 50% viscose and 50% Polyester. It measures 4 inches wide which is the same on my original curtains. I bought some of this at Joann Fabrics for about $1.50 a yard. You will need a lot since you have to use it on the top and bottom of each panel. I bought a roll of 50 yards for about $26 at a wholesale website. Shipping time is long but worth it to save the money.
Shade,Drapery Tapes,Cord | Non-Woven Drapery Header - JKM
Pic#2 My finger outline the space where the pleat tape is concealed within the panel. The old curtains are lined. The curtains I am making are not. You have to leave extra height on top and bottom to make a hem over and cover the tape if you are not lining them.
Pic#3 This is the front of the curtain. Making the pleats in both directions is as easy as folding like a paper fan.
Pic#4 This picture show the inside of the curtain. You can see they are lined.
More pics coming.
Cheers,
Cara, John & Johnny
