05-23-2017, 09:25 AM
#21
2016 19' Flying Cloud
Austin
To get the true state of discharge you need to remove the load and let the battery sit for awhile. That say 4 hours. So 12.3 V may not be an unreasonable reading. I think you are doing the right thing in getting to know the characteristics of your batteries and monitor by testing them. IMO
05-23-2017, 11:23 AM
#22
2017 25' Flying Cloud
Florence
, Alabama
Originally Posted by OTRA15
Thx, Peter, these were good reads.
The Colonel and Southern Belle
05-23-2017, 09:12 PM
#23
1997 25' Safari
Montgomery
, Alabama
Here is a mod from Dick Mansfield's VERMONT BIRDER blog. A solution for the Dometic fridge's lack of a climate control.
http://www.vtbirder.com/power-drain-fixed/
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
05-23-2017, 09:45 PM
#24
2002 30' Classic S/O
Fleming Island
Originally Posted by The Colonel
Yep, grp 24. I'm running one fan, everything else is off. Been going 6 hrs and v indicator in AS shows 12.3, pretty much since I started this am. Not sure how good A measurement I get from that indicator. Shooting for 8 to 10 hours
It sounds like you may be reading the voltage while the fans are running. As ATownTX posted, battery voltage should only be used as an indication of state of charge when there has been no current going into or coming out of the batteries for some time. If you were reading 12.3 at the beginning and it stayed constant during your test it may just be due to the batteries having a load on them.
Al
05-24-2017, 04:09 AM
#25
Sag Harbor
, New York
Al
Good points. Before checking the specific gravity, I would disconnect from shore power for a similar 4 hour period with the Use/Store switch on Store. Check the specific gravity of each battery cell, then put the Use switch back on, and check the battery voltage readout on the panel.
An improved report of battery condition will then be possible.
Cheers,
Peter
PS -- Just a reminder that only distilled water should go into the batteries, wear safety goggles and gloves when working on them, and wait another 4 hours to check SG if you add water.
05-24-2017, 04:38 AM
#26
2017 25' International
Niagara-on-the-Lake
, ON Canada
...Suppose to go BD this fall. ...
What is BD?
Ray B.
05-24-2017, 05:40 AM
#28
Sag Harbor
, New York
Originally Posted by twobikes
Thanks for the link, which shows helpful photos FYI, about disabling the 12-volt feed for the climate control with an inline quick-connect crimp fitting.
05-24-2017, 06:14 AM
#29
Registered User
2016 25' Flying Cloud
Fairfield
BD is boondocking.
05-24-2017, 07:29 AM
#30
Florence
, Alabama
Cheers,
Peter
Thx, I'll do that is soon as I go get a hydrometer
05-24-2017, 07:36 AM
#31
PianoTech
2017 27' Flying Cloud
Lansdale
, Pennsylvania
Good post. Thanks for the battery data. Question - if one watches tv via the pure sine wave inverter will the total load mean a dead couple of batteries in the AM?
05-24-2017, 09:03 AM
#32
Austin
As an example.
Your Television is 120 Watts (maybe), which is 1 Amp at 120 V.
Through the inverter it's pulling 10 Amps from the 12 V batteries. (10 A x 12 V = 120 Watts). There are some losses there, too, through the inverter but, for the simplicity, lets go with 10 Amps.
So, over 8 hrs you would use about 50% of the capacity of your Interstate batteries, which is fine. You would need to account for other 12 V items too. e.g., fans, lights, etc.
A good AC/DC clamp meter comes in handy to monitor your system.
05-24-2017, 09:29 AM
#33
Tampa
Through all of this I'm thinking, "Why not run the tow vehicle every so often to charge batteries or the generator?"
BD does not mean you're on the Moon.
Maybe it's challenging to know every bit of minutia about batteries.
05-24-2017, 10:32 AM
#34
PianoTech
Lansdale
, Pennsylvania
Thanks! I'm getting a generator after this chat.
05-24-2017, 12:33 PM
#35
Florence
, Alabama
Ok, pretty much did that, forgot to put in store. V at batteries was 12.92, V at inside indicator read 13.5. All cells but one at post end read 1.3, one cell read1.28~. I topped off with distilled water and put power on after a few hours I'll check the different cell again, but don't think there is too much of a problem right now. I sure hate dealing with acid.
05-24-2017, 01:08 PM
#36
1955 22' Safari
Laredo
Agm
One of the many advantages of AGM...
05-24-2017, 01:45 PM
#37
Sag Harbor
, New York
Thanks for the update. Be sure to wait an hour after you disconnect from the shore power, to measure the battery voltage. Before this waiting period you can get false high readings.
Have a great trip!
Peter
