Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 12-21-2011, 06:10 AM   #61
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Hey Veg,
To get number bits, you'll need to go to a place that sells specialty tools and fasteners. Places like Fastenal, Grainger, or an independent outfit is even better. Ask Darkspeed where he goes.
See Frank's post number 59 above and read B) good advice from Franks, as always.
Lance
Lance M is offline   Reply With Quote
Old 12-21-2011, 06:17 AM   #62
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Well I was getting bits at vintage online and at the local fastenall but the local fastenall just went out of business.
Darkspeed is offline   Reply With Quote
Old 12-21-2011, 06:40 AM   #63
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Fastenal
Hi Todd.
I'll be in Tampa again today and closed enough from a Fastenal so I can just get some from them.
Looking online I see that they have 2 of the same #, same brand but diff $, any recommendations?
BTW do you need anything from Fastenal?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 12-21-2011, 07:39 AM   #64
Darkspeed's Avatar
1972 31' Sovereign
Originally Posted by VeggieBullet
Hi Todd.
You may find the are different lengths
No I'm good.. My sister says if they sell boyfriends, she needs a new one..
Old 12-21-2011, 08:15 AM   #65
Wimberley , Texas
I have noticed on my 47 Spartan Manor that all of the rivet heads already have a dimple dead center. I am assuming that whatever shank was used to install the rivets created this dimple. That is going to make it much easier to start the drill bit dead center. Does anyone know if these type of shanks are avalible for a 3X rivet gun?
danimal327 is offline   Reply With Quote
Old 12-21-2011, 03:31 PM   #66
1973 31' Sovereign
2007 20' Safari SE
it wasn't that bad at all!
Hi Guys this is not bad at all!
Got the last VV done today and it wasn't that bad. Except for the fact that my rivet gun is not the best so I'm on ebay now looking for something to speed this riveting process.
Can an Air Hydraulic Riveter Gun be used to speed this up?
2 chronicles 7:14
Old 12-21-2011, 03:48 PM   #67
Sure can, as long as you have an extension cord, a compressor and an air hose.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-21-2011, 03:59 PM   #68
Darkspeed's Avatar
1972 31' Sovereign
Ya I got one... Think it is still in the box.. lol.. need to borrow it
Old 12-21-2011, 04:03 PM   #69
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Not sure the size of the rivet, but the dimples (MS20470-AD5) still exist in new rivets today. They are not created by the shank.
FC7039 is offline   Reply With Quote
Old 12-21-2011, 04:08 PM   #70
FC7039's Avatar
Allen , Texas
If you are using "pop" rivets, a gun is so much better. I had an air/hydraulic. I ended up buying a straight air gun made by Pop of all people. One of the best tools I have bought. Even for the price.
Old 12-22-2011, 11:57 AM   #71
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The rivets you posted a pictured of are AN455AD4-X (#30 drill) which are extremly hard to find anymore and replaced by MS20470AD5-X (#21 drill). Below is AC 43.13 that explains the numbers, Identifiers,alloys, etc
The best drill bits to use are 135 degree split tip in cobalt at around 3000 rpm, more expensive be last 10X longer.
I personally have never used one of those guide tools as they were not available when I started doing aircraft sheet metal way back in 1976
Old 12-22-2011, 12:42 PM   #72
Central , Mississippi
I will add that I used one of those drill guides and found it was very good at STARTING a hole. It is super fast to hit a bunch of rivets and create a very centered shallow hole. I then used a regular bit to finish drilling out the rivet.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 12-22-2011, 01:34 PM   #73
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Many years ago, I found these for sale in solid carbide, double ended (I think at the EAA airshow back when it was still in Rockford, IL.) ... in a SHORT version - perhaps two inches long. They are terrific, if you can find them - because of their short length and hardness, they don't flex or wander at all, and they have lasted for literally decades and have drilled zillions of rivets and rivet holes. Also, because of their sharpness, and when used at highe speeds, they cut fast and clean. Chuck up one of these in a high speed air drill, and yer' ready to go!
Only drawback is that you need a diamond wheel to sharpen them. Then again, I've never needed to sharpen them!
AirsDream is offline   Reply With Quote
Old 12-23-2011, 09:26 AM   #74
Wimberley , Texas
Just a quick question. I went to the Airparts web site https://www.airpartsinc.com/shopexd.asp?id=189 . They show a ms20470ad4-x. Would that not be an 1/8th inch rivet/ #30 bit? I want to make sure I don't end up buying a 1000 incorect rivets.
Dan
Old 12-23-2011, 02:07 PM   #75
Aerowood's Avatar
Arvada , Colorado
Let me explain one other thing. AN455AD4-X rivets have a manufactured head of 5/16 diameter. In order to replace then with a MS20470AD rivet you will have to use a 5/32 rivet which has a manufactured head diameter of 5/16.
So if you want the diameter of the replacment rivets to match closely to the exisiting AN455AD4-X rivets, you will have to order MS20470AD5-X rivets.
Also check that Airparts rivets do not have as I call the, "Paragraph on the head", which is a bunch of lettering. I order all of my rivets from here
Genuine Aircraft Hardware Co.
Old 12-27-2011, 01:44 PM   #76
Wimberley , Texas
Thanks Aerowood!
You a truley a rivet master!
Old 03-22-2022, 08:48 AM   #77
Projet2907's Avatar
2017 19' International
Rosemere , Quebec
Originally Posted by Frank's Trailer Works View Post
It can.
I however, drill the original buck rivets with an 1/8 bit. That generally gets rid of the head and shaft. Not always though. The original rivets were 1/8" with the bigger head. We now use 5/32" with smaller heads. I then drill it with a #20. I try my best to drill once, straight in, then once straight out. I do not push the bit in and out as some do. That makes for a sloppy hole. So far this seems to work just fine (for me).
Do You use a bit stopper? what model?
Projet2907 is offline   Reply With Quote
Interior Rivets - What size? perryg114 Ribs, Skins & Rivets 19 06-11-2021 11:47 PM
Ugly Rivets! Roadrunner Ribs, Skins & Rivets 2 12-04-2011 11:24 AM
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
