Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-16-2015, 10:21 PM   #1
2018 23' Flying Cloud
Springfield , Missouri
Repairs or seam sealing on the top of my Airstream
Can you actually get on top of the Airstream? If so do you stand only where the rivets are? Thinking of switching out the exhaust fan and re-sealing all the places that were previously sealed at the factory. Its been seven years.
cfishii is offline   Reply With Quote
Old 06-17-2015, 04:45 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes- and only stand on rivet lines. Tread gently, if you feel the skin moving, you're not stepping in the right place. And don't stand on the end caps.
The factory tour said to get on the roof on the awning side. I think that's for safety- if you were to slip, the awning header would stop you from going over the edge.
2019 Ford Expedition Platinum
Old 06-17-2015, 09:42 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes, you can 'walk' on the roof. I am about 270# and I do. However, I also place either 3/4" plywood or several wide boards on the roof, bridging the RIBS/rivets.
It is important that you also place some 'non-skid' material on roof before placing the board(s)...
Next, you climb up using a ladder, which is properly padded so it doesn't scratch...leaned against the curb or street side ZipDee awning.
Oh, make sure you have a "ground support" person to hand tools, parts, call 911 if you fall, of course the call would happen after the requisite YouTube video being posted successfully.
Peace and Blessings..
Channing
WBCCI# 30676
Seam sealing from the inside? ironheadxlch General Interior Topics 19 09-04-2015 08:08 AM
interior seam sealing GR8DANE Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-09-2013 11:58 AM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Need Advice on Seam sealing material nm1oqrz Ribs, Skins & Rivets 4 02-16-2011 11:44 AM
Seam sealing - again Fyrzowt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-08-2006 12:01 PM
