Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 02-26-2004, 05:02 AM   #1
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Ebay rivet shaver
The one problem with Olympic Rivets is they need to be shaved after installation to look good. I will probably end up following past post's recommendations to use a Dremel tool due to the high cost of rivet shavers.
But, just in case a bargain was to present itself, I started watching rivet shavers on Ebay. I believe all the ones I have seen up to this point are Government surplus from the aviation industry. I would think these would work fine, but do not know what the specifications mean. For example,
Used, 1/4-28 Threaded Bits, 1 Quick Change Magnavon Microstop
1 very good surplus 1/2" Carbide RIVET SHAVER Bit
365 x .124 collar cutter / hollow counterbore - new
etc.
What specs are appropriate for shaving Olympic rivets?
Tom
Old 02-26-2004, 11:38 AM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
www.airpartsinc.com
Sounds like the one they sell. I bought one and it doesn't work in that application. It's won't center on the rivet and the cutter is not convex.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-26-2004, 11:43 AM   #3
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
I got my rivet shaver at AirstreamDreams. It works great and should last a lifetime.
Tinsel Loaf is offline   Reply With Quote
Old 02-26-2004, 11:57 AM   #4
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
el cheapo shaver
I haven't had occasion to shave a lot of rivets so I've just used a mounted point (miniature grindstone) in an electric drill. They are available at most hardwares for just a buck or two.
Works well for me.
Rog
Rog0525 is offline   Reply With Quote
Old 02-26-2004, 02:54 PM   #5
COArgosy78
Obsessed with Moonunit
COArgosy78's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 45
Rog - Thanks for posting w/picture. That could come in real handy in about 2 weeks! Always good to have a less expensive alternative.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
test
