01-22-2010, 05:13 PM
Remember, Safety Third
Catfish Corners
, Georgia
Questions about interior wood
I'm in the process of replacing all of that way past ugly plastic in the interior of the Overlander with real wood (cabinets, bulkheads, gaucho and so on). My brother-in-law recommended that I keep the window shades closed to prevent the wood from being ruined by UV from the Sun. Generally, I leave the windows in the galley and the living room uncovered to allow some sunshine and heat in there during the cold months. The rest of the windows stay covered year round.
The new wood is stained a reddish color with two coats of polyurethane. Whadda y'all think? Covered or not?
TIA,
01-22-2010, 05:22 PM
1964 17' Bambi II
Schererville
, Indiana
I always keep my shades pulled throughout the trailer when I'm not using it. The UV light from the sun not only fades wood finishes, but it also is very hard on upholstery in the trailer. I don't think the cold weather has any effect on the interior if the shades are pulled IMHO.
Becky
1964 Bambi II
1988 Avion 32S
01-22-2010, 05:58 PM
Some woods and finishes are more susceptible to fading than others, and some woods such as cherry actually darken rather than fade. Dark stained wood fades more than light stained wood, in general. The effect of direct sunlight on wood veneers is really pretty severe. It will dry the surface veneer out too quickly compared to the core, and you will get very fine cracks developing in the finish, and then into the veneer itself. That eventually leads to seperation of the surface veneer. A little moisture added to the situation will speed it up drastically.
Your woodwork will last longer and look better if you keep it in the dark and keep it cool. For storage I keep all my windows covered up, and leave a vent cracked open just a hair to allow heat to escape on those really hot days.
As a side note: when you see really nice furniture sitting out at a yardsale or parking lot sale in direct sunlight, by the time you got there it was probably damaged. It can happen very quickly.
Rich the Viking
01-22-2010, 06:20 PM
1972 23' Safari
Houston
Also the Curtains
Keeping the curtains closed is good for the wood but bad for the curtains as they would then fade. Then again some windows also came with roller shades, which is probably the cheapest and easiest to replace. So I guess in priority it's protect the wood first, curtains second, shades last. What do you other experts say?
01-22-2010, 06:21 PM
1992 29' Excella
JOY IN
here you go take a look, Woodworking Plans & Tools | Fine Woodworking Project & Supplies at Woodcraft
TIA,
01-22-2010, 06:38 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
No Idea
But I cant wait to see the pictures of the insides.
01-22-2010, 06:54 PM
I made my own window covers to fit into the screen holders. They are 1/8" thick mahogany plywood, with a layer of Prodex insulation laminated to one side. I install them with the Prodex against the window. I can completely black-out my interior on the brightest of days and increase my insulation factor at the same time. It's perfect for storage also, as no one can even look in through a window, and it stays cooler and darker than anything else I could think of.
Rich the Viking
01-22-2010, 06:55 PM
2022 30' Flying Cloud
Phoenix
Covered. The sun will fade anything in its path. Shades and curtains are usually made to handle the UV rays and are easily replaceable compared to the wood in your trailer.
01-22-2010, 07:23 PM
Catfish Corners
, Georgia
Well, since you asked Professor...
It looks a little rough in there now, I'm going to pull it over to my buddy Eric's
tomorrow to finish that cabinet around the 'fridge. Next up is the Gaucho replacement. Hope to turn that into a queen sized sleeping area, dining table, TV viewing, home theater, stereo playing, etc. place to relax. Well, you get the idea.
01-22-2010, 07:31 PM
1992 29' Excella
JOY IN
looks great, I want to do mine now,
01-22-2010, 07:39 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Wowsers, thats all net!
01-22-2010, 08:52 PM
1970 27' Overlander
ARLINGTON
, TEXAS
wow..the wood replacement looks so, so good. Love the movement in the wood. What kid of wood? Did you use the old aluminum frames and insert the new wood? Are you replacing your kitchen too? LOOKS FANTASTIC!!!!!!
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
01-22-2010, 09:37 PM
Catfish Corners
, Georgia
Tex, Basically what we did was use the old plastic parts (walls or bulkheads, bed frame, etc.) as patterns. The wood is 1/4" birch plywood that comes in 4' x 8' sheets. Each sheet runs about $16/$17 per sheet and there is quite a bit of waste. But, my friend Eric has a wood shop and uses the left over pieces for his projects (that he sells for real money ).
The birch is finished with Minwax #245 (IIRC) Pecan stain. I need to check that number, btw. Then two coats of polyurethane. The silver trim is the original trim from the factory. It was originally a brown to gold color. I washed it, then cleaned again with acetone. Next came a coat of automotive primer, then a coat of automotive silver paint. I really like the look of it. I'm using stainless steel screws and rivets to fasten everything together. When you look at it up close, the "red" stain and the silver fasteners look really great together.
This is the truly fun part of the restoration. Things are starting to "look" nice. It's what I've been waiting for these many years. Your trailer has natural wood, IIRC, not all that nasty plastic stuff like ours. You could probably refinish the wood and it would look great! Let us see your handy work.
01-22-2010, 09:53 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Looks Great!!!
You found some exceptional birch plywood. Most of the stuff I have gotten doesn't have nearly the character that does. The finish still doesn't look as dark as I was expecting from your initial post. That will also make fading less of an issue.
I would still close the curtains/blinds when I wasn't looking out the windows.
I look forward to more photos of your progress. My '83 Excella has what may be the penultimate ugly plastic on the bulkheads. If you look at the top in this photo, you can see the plastic peeling back! I'm looking at options for redoing the bulkheads and cabinet fronts.
Vaughan
01-22-2010, 10:07 PM
1968 24' Tradewind
1959 17' Pacer
holly springs
, Georgia
Jim and Susan
Have not seen it since you enclosed the fridge, looks great! The color looks even better than the pictures.
Many bad experiences w/ uv esp. on fabric, but also on wood, keep it covered.
Kevin
01-22-2010, 10:08 PM
I love Airstreams...
1989 29' Land Yacht
Haines City
looks good....
your friend Eric has a really nice cabinet shop.....really really really nice and the work that comes out of that shop is beautiful....
ok...one question...the small pieces can be stained and put up in place....stained then installed....
when doing a wall piece as in a full sheet attached as a wall would you think that it should be stained in place...as in put the wood up and then stain...i have a project that needs walls and i am thinking of putting the wood up then staining it.... any ideas....
01-22-2010, 11:35 PM
1972 23' Safari
Houston
Real Wood over old laminate
Replaced some of the panels in my 72 Tradewind and used Veneers on the rest. Stained after cutting before installation. Jim's birch looks really good. I used Red Oak. Closely matched the original Maple look and goes with the Tambour.
01-23-2010, 07:46 PM
Catfish Corners
, Georgia
Originally Posted by vswingfield
Looks Great!!!
Yuk! That is a mess! And way too dark, IMHO. I picked up on a post by Uwe (one of our resident geniuses here on the forums) in his '63 thread. I have been going thru the birch at our local Lowes for the last couple of years and every time one of 'em looks nice, I grab it. There does seem to be a wide range of looks when it come to the birch plywood. In case I didn't mention, this is plain old 4' x 8' birch ply. I think the stain helps the look a bunch.
Thanks for the advice on the UV issue.
01-23-2010, 07:49 PM
Catfish Corners
, Georgia
Originally Posted by kevinb
Jim and Susan
Kevin
Thanks, Kev. Beer and BBQ next weekend, if yer game.
01-23-2010, 08:00 PM
Catfish Corners
, Georgia
Eric and his shop are available for hire if you need them.
All of the woodwork has been cut/stained/poly'd while in the shop or my back porch, with the exception of one bulkhead (the one next to what will be the sink). The one that was insalled first and then stained and poly'd had problems with runs in the poly phase of the install. I learned from that the best way was to have to wood laying horizontal when applying the coatings.
It probably takes longer to do it this way, but I only want to do this once if possible. We're at the phase where stuff is really starting to look great. I'm a little anxious to see how it's gonna turn out.
