Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-27-2007, 09:48 AM   #1
Profile:  Springfield , Ohio
Oak Cabinet Door Retainer Strips
I have a 1987 345 motorhome with oak cabinets built with an outer frame and a raised panel insert. The insert panels are secured by a brown plastic strip on all four sides of the panels which slip into groves on the frames and then secured with brads. I have had the plastic strips fail on one door and I tried to glue the insert in which worked but is not beautiful. The strips have now failed on another door. I would like to find a source for the extruded plastic strips which I assume are a standard product for some application. I doubt that Airstream had an expensive extrusion die made just for their application.
JKWoodrow is offline   Reply With Quote
Old 07-27-2007, 11:33 AM   #2
RE: Retainer Strips
According to Airstream, the retainer strips are no longer available.
I found some screen door window retaining clips and some #6 X .500" screws at Lowes that are doing the job.
Old 07-27-2007, 12:54 PM   #3
SaabLover's Avatar
Profile:  1974 31' Sovereign
Almost Always Sunny Sarasota , Florida
Images: 12
You might try Outwater Plastics Industries.
They are a great source for all types of fittings that would work for an Airstreams interior.
Panel retainer
Tambour
Tee mouldings
Search Catalog from this page its easier
Use Keyword or Item #
I hope this will help anyone this needs this or other items.
You might need to try to get some other members together for a group buy.
SaabLover is offline   Reply With Quote
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 05:53 PM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 11:19 PM
Cabinet Catches Danno Cabinets, Counter Tops & Furnishings 1 06-18-2002 10:12 AM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 08:22 PM
