Old 02-06-2017, 02:47 PM   #1
Luminous
LY007's Avatar
1983 27' Excella
Vesuvius , Virginia
Kitchen Counter Slope (?)
I removed the original kitchen counter from my 83 Excella.
While doing some measuring for the new top, I noticed that the long piece of aluminum angle that is attached to the outside wall and supports the back of the counter is 1.5" higher than the cabinetry the countertop sits on. Everything looks original and I see no signs of prior modifications. This means that the counter slopes down inward. Is it supposed to be like this? Maybe so water on the counter top could flow towards the sink and floor instead of the wall?
I assume there must be a reason for this - no way the factory could have been that far off.
It's easy enough to fix, but I'm wondering if it's supposed to be that way.
Thanks, and sorry website elected to rotate photo 90 degrees.
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 02-07-2017, 03:14 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
How about, the assembler was putting in material to meet with the other material; level and plumb was secondary to making things fit together.
On my 1986 trailer I found most walls and cabinets were not square or plumb. All the parts fit together and looked OK, but when I installed a new floor that was square the errors were pretty easy to see.
sgschwend is offline   Reply With Quote
Old 02-08-2017, 10:35 AM   #3
Luminous
LY007's Avatar
1983 27' Excella
Vesuvius , Virginia
Well I have to say that even by RV manufacturing "standards", this was pretty wacky. But it does explain why my original countertop was warped along its length.
I moved the bracket down this morning and the new butcherblock oak top is going in as soon as I finish with a few more coats of oil.
Steve
83 Excella 27
07 Tundra Limited
Old 04-13-2017, 09:39 PM   #4
1976 Argosy 26
Henderson , Kentucky
Images: 21
Read you post and I wondered how you reattached the counter brace to interior wall? I was interested in seeing if stainless steel screws and if any special precautions needed to avoid aluminum corrosion? thanks.
Ky76Argosy is offline   Reply With Quote
sagging kitchen counter tandemfish General Motorhome Topics 6 10-17-2006 07:39 PM
Removal of the kitchen counter top fossil Cabinets, Counter Tops & Furnishings 3 04-11-2006 10:29 AM
Kitchen counter backsplash ideas Safari Tim Cabinets, Counter Tops & Furnishings 13 06-08-2005 03:50 PM
Removing Kitchen counter assembly quality parts Cabinets, Counter Tops & Furnishings 4 12-11-2004 05:47 AM
Re-Laminating Kitchen Counter Pick Cabinets, Counter Tops & Furnishings 4 05-24-2002 07:38 AM
