Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 11-14-2010, 04:58 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Allure for a countertop surface?
Hi - I'd like my countertops to match my floors. Traffic Master Allure has a few paterns that would work for me. What would the disadvatages be to using Allure for a countertop? I'd use 5/8" plywood underneath and glue the flooring down. We always use cutting boards and the flooring seems very tough.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 11-14-2010, 07:17 PM   #2
_
vinyl or planks?
doesn't matter the issues are similar.
it may not be food safe, even for incidental contact.
it is surely not heat tolerate.
while one might think cutting boards are a solution to these issues,
the counters will be wiped down with the same products used for dishes and pots and food.
there will direct hits from utensils, pots and other sharps...
exposing more of whatever is under the shiny layer.
but what the heck, it will take years 4 any adverse effects.
seriously have u looked at what vinyl flooring emits and how it reacts to household chemicals?
bad idea.
still i am confident some1 has done it and will shortly provide u with feedback.
cheers
2air'
Allure TrafficMaster 66Overlander Floor Finishes 164 08-13-2015 06:48 PM
Armstrong or Allure frankandsue Floor Finishes 2 09-15-2010 03:21 PM
New Solid Surface Countertops adonh Cabinets, Counter Tops & Furnishings 43 06-02-2009 09:17 AM
Surface Oxidation Lumatic Ribs, Skins & Rivets 11 01-22-2007 06:28 AM
Brushed Surface Help Randy Johnson Ribs, Skins & Rivets 2 05-05-2003 04:57 PM
