Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-18-2002, 09:41 PM   #1
PatCrusse
PatCrusse's Avatar
Profile:
Why use a converter?
I just got back from a weekend trip. While enjoying a quite weekend night, my converter gave out. It is not a Univolt. Instead, it was a cheap converter installed by the PO. The converter no longer charges the battery or converts 120V to 12V.
As I was considering replacement options, I though "why do I even need a converter?" My wife and I enjoy staying in state campgrounds the most, and there are seldom electric hookups. We realy just need to be able to charge the battery in between trips.
I also figure the when we do stay at a campground with hookups, the charger could replace some of the electricity that we use. We would probably never no the difference.
I have a nice 10 amp charger that switches to a maintinance mode when appropriate.
What are your thoughts?
Patrick
Patrick Crusse
'74 Tradewind 25', Rear Bath - Center Twin, Mostly Original except wood floors.
Tow Vehicle: '99 Dodge Ram 2500 w/ Cummins Diesel, Auto Trans. Tows great even without equilizer hitch.
PatCrusse is offline   Reply With Quote
Old 11-19-2002, 04:16 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Try it for awhile and see what happens. You can always get a new convertor later if you find that you need the 120v. If you survive the weekend on the battery it will save you some $$.
John
74Argosy24MH is offline   Reply With Quote
Old 11-27-2002, 07:52 AM   #3
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Everything runs on 12V. Radio, pump, lights, control center. When boondocking, or dry camping, you run off of the battery, and have to conserve. When at a campground, you are hooked up to 120VAC or 240VAC, the converter gives you a constant source of 12V to run everything, as well as charge the battery.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Converter busted? Navigator Electrical - Systems, Generators, Batteries & Solar 4 01-06-2004 11:22 AM
Power converter "fuse" rfield54 1999 - 2004 Bambi 0 09-02-2003 03:26 PM
'92 Excella Converter Mark Wiltrakis Electrical - Systems, Generators, Batteries & Solar 11 04-16-2003 07:39 PM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
test
