Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-16-2019, 10:37 AM   #1
2020 23' Globetrotter
Brea , California
WEN 2250 generator has trouble to run furnace?
Hello All.
I'm a super newbie, Globaltrotter 2019, 23' I'm in a stage of firgure-things-out. Bought WEN 56225i Super Quiet 2250-Watt generator very similar to HF Predator. I know WEN 2250W would not be sufficient to run Air, but I had a troubled run heater (furnace). The thermostat was set "Auto" when Temp set to 72F, outside was 58F. when heater(Sounds like electrical unit kicks in as well, not only France), the generator's warning lights were blinking and it was stopped. My guesses are following:
1. I should set the thermostat to "Furnace" instead "Auto"
2. When "Auto" kicks to either Air or heater, I'm required to have at least 3KW+ generator.
I might be completely wrong...please guide me a super newbie, and greatly appreciated many guru's advice.
kevinum is offline   Reply With Quote
Old 11-16-2019, 11:03 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Are you trying to run a heat pump with the generator or a propane furnace?
Old 11-16-2019, 02:40 PM   #3
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Set to FURN not Auto. Auto will attempt the heat pump. Hence your problem.
pcskier is offline   Reply With Quote
Old 11-16-2019, 02:54 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I agree with pcskier, Auto will attempt to run the Heat Pump (which is your rooftop AC unit). Select Furnace and you should be fine on generator.
If you’re on shore power you can use Auto which will run the Heat Pump until temps get too low and then switch to the furnace.
Welcome to the Airstream Community and Forums! You have a beautiful unit.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 11-16-2019, 02:59 PM   #5
2015 25' FB Flying Cloud
Sandy , Utah
I agree. Note: the furnace will run on battery only. You will only need to use the generator to charge the batteries.
rocco52 is offline   Reply With Quote
Old 11-17-2019, 10:58 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I agree with all above
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 11-17-2019, 04:09 PM   #7
jeffmc306's Avatar
McHenry , Illinois
drbrick, I just checked out your Married with Aistream blog link from your signature and really enjoyed reading the posts. Nice job; very well done!
2018 FC23FB
WBCCI# 10258
RETIRED!
WEN generator AWCHIEF Generators & Solar Power 1 06-09-2017 11:24 AM
fridge has not run in 15 years + alistheman Refrigerators 10 06-24-2015 07:04 AM
AC has trouble starting TravisA Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-28-2008 12:32 PM
